05-30-2008, 09:26 AM | #1 |
Wishin' I had more money!
Sway Bars...
My truck is an 80 C10 Scottsdale, 2wd, about to be slammed to the ground with spindles, 2 inch springs, and a flip kit.
My question is, how beneficial do you guys think the stock sway bar is? I don't have the money for an aftermarket, but my truck already has the holes, and a stock one is only like 8 bucks from the junk yard, including the bushings. I already looked at it, and the bushings are good and the bar looks almost new. My truck didn't even come with one from the factory, so I would be adding it, but it's already got the mounting brackets. Thanks, Chris |
05-30-2008, 01:10 PM | #2 |
67-72 parts collector,…
Re: Sway Bars...
Definitely worth it! Use the stock 1 1/16" sway bar or even a 1 1/4" sway bar off the 3/4-ton trucks. It will drive so much better. If you're going to slam it,... skip using the factory front frame stands and bolt it directly to the frame. DO it!
05-30-2008, 03:48 PM | #3 |
Re: Sway Bars...
I lowered my '80 the same way and bought a junkyard sway bar off of an '89 Burb about a month later and man, what a difference! Well worth it IMO. My truck didnt have the brackets on it so I bolted it right to the bottom of the frame after drilling a few holes. Ive heard that is the way to go anyway because if you ever hit a speed bump or bottom out a little the sway bar brackets would be the first thing to hit the pavement using the stock brackets. You could buy the lower profile brackets from ECE but bolting directly to the frame has been done plenty of times and its cheaper. I will try to snap a pic this afternoon so you can see my setup.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
05-30-2008, 04:48 PM | #4 | |
Re: Sway Bars...
05-30-2008, 06:00 PM | #5 |
Magnificent bastard
Re: Sway Bars...
I can say from first-hand experience that this is absolutely true.
1977 Big Block Burb |
05-30-2008, 05:36 PM | #6 |
Happy to be here
Re: Sway Bars...
I would spend a few bucks and get new bushing. Even if the old ones look good, why not replace them now and be done. They are fairly cheap at your local autoparts.
05-30-2008, 05:58 PM | #7 |
Re: Sway Bars...
hey x......there was a thread on this the other day.you might find some intresting reading.i think it's well worth doing.you'll feel a big difference.like ken says.get some new bushings.there not that much.the old originals you'll find at junkyard will probably be in sad shape.
" Never look up a dead dogs butt." |
05-30-2008, 08:12 PM | #8 |
Surviving, one day at a time!
Re: Sway Bars...
It will make a very noticable differance, no more sea sickness from body roll. If you do put one on use the poly urethane bushings they last longer and you'll get better performance. if you can find a rear sway bar it will improve even more.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" |
05-30-2008, 10:39 PM | #9 |
Re: Sway Bars...
Thanks for the info guys. Gonna pick up the sway bar saturday morning and get new bushings as well.
Still wanting to see that picture if possible. |
05-31-2008, 12:42 AM | #10 |
Re: Sway Bars...
I will take it when I get home and post it up in the AM at the latest.
05-31-2008, 02:30 AM | #11 |
Re: Sway Bars...
sounds good! Not doing the big project till sunday anyways.
05-31-2008, 03:30 AM | #12 |
Manual Transmission Club
Re: Sway Bars...
I posted about sway bars in another thread, someone else posted a picture. I hopefully have mine on this week end if not then the middle of next week, I’ll let you know how it goes.
http://67-72chevytrucks.com/vboard/s...d.php?t=293454
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
05-31-2008, 05:47 AM | #13 |
Re: Sway Bars...
That was mine, he wants pictures of a stock sway bar. Mine's aftermarket the ends mount differently.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" Last edited by GMBowtie79; 05-31-2008 at 06:25 AM. |
06-06-2008, 10:12 AM | #14 |
Re: Sway Bars...
Here are those pics I promised...and a shot of my little helper.
06-06-2008, 03:51 PM | #15 |
Re: Sway Bars...
Thanks for the pics man!
I haven't had time to get it yet, but I plan on it. We had so many problems with the spindles and flip kit that I don't even wanna mess with a sway bar yet. |
06-07-2008, 12:28 AM | #16 |
Re: Sway Bars...
It's a pretty easy install, you won't regret it. In my opinion it's a must for these trucks, they feel kind of dangerous without one. I picked up mine at the yard for $40 with all the brackets (they pulled it) and spent $20 on moog poly bushings. It's drives like a different truck. One other trick for clearance it to put the bar on the topside of the big front brackets, this will pick up a couple inches with no drilling and it's about the same height as the ECE brackets all together.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
06-07-2008, 06:44 AM | #17 |
It Is What It Is,,,,
Re: Sway Bars...
Yes, super easy install.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
06-07-2008, 10:35 PM | #18 |
Re: Sway Bars...
The absolute best 20 dollars I have ever spent on my truck. I wish I had one fore the rear. Mine came from an 87 3/4 ton burban.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
