06-02-2008, 08:49 AM | #1 |
Big Block install Question...
A friend of mine is installing a Chevy Big Block.
Our question is: We are using the factory BB mounts from a 74 big block donor truck... brackets, rubber mounts, cups.. The problem is it seems to sit very high above the crossmember (approx. 4-1/2" above crossmember. Very much so higher than a small block '68 we compared to he is currently driving... Any thoughts or input here...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 06-02-2008 at 08:50 AM. |
06-02-2008, 04:29 PM | #2 |
its all about the +6 inches
Re: Big Block install Question...
not to be a smart ass... but my thoughts are to locate the correct towers and mounts off a 68 - 71, or a 72 truck.
06-02-2008, 04:49 PM | #3 |
I'm a poor spectator
Agreed. I put a 396 in my blazer a few years ago and used factory small block mounts to the factory crossmember, had ZERO issues with that part.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
06-02-2008, 05:36 PM | #4 |
i used stock small block towers & mounts also, but i pushed the whole works back as far as i could for weight transfer purposes
06-02-2008, 09:30 PM | #5 | |
Second... if we used the SB towers, do you need to modify them in any way? Aren't Facory BB towers hole larger for the motor mount bolt. And... which rubber mount did you use?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
06-02-2008, 09:36 PM | #6 |
the towers in a 72, are a one year only item. They are better than the 68 - 71, and fit properly unlike the 73 - 87. As for the actual mounts... I think the clamshell BBC mount is in fact the same 72 - 87.
I wasn't trying to be a PITA, which it looks like I was coming across that way. Sorry. |
06-03-2008, 01:00 AM | #7 | |
06-03-2008, 12:53 AM | #8 |
Recovering 67-72 Addict
I know that I have seen posts where people have successfully retrofitted the 73 and later BBC motor mounts. I haven't had the chance to compare a '72 to a '73 and up but from the pictures that I have seen they sure look very similar. I am sure that someone will chime in sooner or later who has experience with this retrofit.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
