06-02-2008, 02:38 PM | #1 |
Which Hitch?
I did a search and didn't find an answer to my question.
My neighbor has a 78 Suburban that he's parked. It has a heavy duty Class III/IV hitch on it. I can get it cheap (free ) but I don't know if it will fit. Will this hitch from a 78 Sub fit my 70 Stepside pickup frame or do I need a different hitch? Anyone have the correct number/brand that will fit? Last edited by 70inline6; 06-02-2008 at 02:38 PM. |
06-04-2008, 09:32 PM | #2 |
Re: Which Hitch?
I took a 78 Blazer hitch and put it on my old 72 suburban. Only thing I had to do was drill a couple of hole in the frame. The frame was the same wideth but it sat alittle bit lower than I would have liked.
I'd say if it's free take it and see, all your out is time.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
06-05-2008, 12:05 AM | #3 |
Re: Which Hitch?
I put an ECE 67-72 'hidden-hitch' set-up on my 74 & it only had to be modified slightly because of the leaf spring bracket(s).
06-05-2008, 07:56 AM | #4 |
Re: Which Hitch?
Thank you both.
06-05-2008, 09:21 AM | #5 |
Re: Which Hitch?
I bought mine from JC Whitney, name brand class 3 for around $120 shipped. Supposed to be a direct bolt on, needless to say I did end up drilling a couple holes and use either lock nuts or lock washers with a dab of Loc-tite!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
