Wheel Question
Can a aluminum rim that has been sandblasted be restored to a nice shine ? Its basically a dull grey now, can it be restored to have that nice mirror shine ? How much work/money could a person expect ? Just wanted some opinions before I make a purchase. Thanks
shane |
![]() Join Date: Jun 2002
Re: Wheel Question
With a LOT of work anything can be shined ( my son is tumbling rocks in the garage as I write this) If he can polish rocks, you can polish those wheels!
It would be a lot of work but it can be done. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
Re: Wheel Question
Just get some compounds and a buffing wheel along with a little elbow grease and it should be doable ?
Re: Wheel Question
lots of wet sanding... Depending on how bad the finish is depends on how heavy of a grit you start with... Sand blasting is way too agressive!
Try this link... http://www.englishcustompolishing.co...aluminum1.html
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
Re: Wheel Question
Thanks for the response. Im gonna go and check them out and see what im dealing with. I know he sandblasted them cause he planned on powder coating them ?? Wish he wouldnt have. Ive been looking for these wheels in an 8 lug and they have been hard to come by. Might just try it for the experience anyways !
C10 addict
Re: Wheel Question
It can be done, it's just a time consuming process. You have to sand it and then polish it. I would start with 120 grit, then 220, finally 320. Be sure not to sand away any curvature or features in the wheel. Each time you switch grit, you sand 90 degrees to the previous sanding to remove the previous grit sanding scratches. After 320 grit, clean it well then you will polish it with tripoli compound, clean it again and polish it with white compound. Clean off the residue and now it should be nice and shiney. You can leave it like this or clear coat over the top. Hope that helps...
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 06-04-2008 at 02:27 PM. |
