Long & Short Water Pumps
im looking to buy a serpentine belt kit for my truck soon. The one I like says specifically for long water pumps, and I dont see a short pump version at all similiar. Is it alright to change my short pump to a long pump and change everything else to match? Its a '68 327 if that matters. Thanks DOOCE
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() Last edited by dooce; 06-05-2008 at 11:42 AM. |
1962 C-10
Re: Long & Short Water Pumps
You can use a LWP on a 327. That's what I have on mine.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Are you sure it is a Short pump. IE can't get you hand behind it..
If you are getting a serpentine for a Long pump, everything else will match when you swap pumps. There is nothing specific to the motor that will require a short pump except for the accessory brackets so if they are changing you are fine.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Old Heap Driver
You may need a reverse rotation water pump.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
how would i know if i need a reverse or not?
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() |
You don't have one if you are using normal V-belt pulleys.
If you aren't running a serpentine setup, you don't have a reverse flow waterpump.
the kit i am looking at buying is a serpentine belt kit with pulleys and all. so will i need a reverse w/p or not? you kinda lost me ^. its been a while since ive be able to mess around with the truck, but i think i am able to stick my fingers between the block and w/p. you can see the timing chain cover in the pic. thanks again for the help, DOOCE
That is a long pump. It is also standard rotation.
You are going to have to get a new reverse pump either way if you want a serpentine setup.
thanks for the help!
Phone's ringin Dude.
![]() Join Date: Mar 2007
Hey dooce, how's K-town nowdays? Sure do miss that place!
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
not too bad. its still the hang out for all the americans. Chucks, Thirsty Nellys, Hannen Fass, Nacht Shicht is the place to go. The euro rate is crazy right now. it flucuates anywhere from .62 - .64. How long ago were you here?
I just left there last December. Man I miss ol' Chucks Diner. Didn't go many other places in that town, just did alot of traveling. But Chucks was the place.
All bs aside.... What kinda serpentine setup you goin with? You got picks??
im going to go with a zoops system.
#15 |
is reverse rotation clockwise or counter clockwise?
#16 |
#17 |
i looked and i cannot find it on the site. the part # for classic industries is z6143 or z6144. i dont know which one i need yet. got to wait til my truck gets here.
#18 |
ok, i found them on the zoops site. the part #s are 6143 and 6144
#19 |
You don't need a reverse pump for either of those serpentine setups. Nice Kit wouldn't mind havin that myself.
I dunno if ya seen this when you were lookin>> |
#20 |
yeah, thats it. where did you find that pic? the only pics on zoops of it were pics of the pulleys and brackets, not assembled on an engine. thanks for the heads up
