Old 11-07-2002, 10:14 PM   #1
frisky68
No dash lights
I went from a non gauge dash to a gauge dash and now have no dash lights...I followed the instructions from GMC Pauls website on swapping wires on the wiring harness...and the dash gauge wire has power to it in the harness...I do have turn signals and the temp light comes on when you turn the key on to start...but no dash lights...could a non functioning reostat on the light switch be the problem ??? Or where else should I look ???
94 K1500 SWB w/ 4" body and suspension lift
frisky68 is offline   Reply With Quote
Old 11-07-2002, 11:11 PM   #2
useRc10
useRc10's Avatar
i thought mine was the rheostat spring for a long time but actually there was a blown bulb...there in circuit so they all go out with one...check that...its easy enough...-Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 11-07-2002, 11:23 PM   #3
frisky68
guess that information would have been helpful in my original post..I replaced all the bulbs w/ new 1's.
Old 11-07-2002, 11:33 PM   #4
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
got a ground?????
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 11-08-2002, 01:27 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Interesting, your lights should not be in series...I have one missing on the fuel guage on mine...but all the others work fine.
If the fuel guage and turn signals are all working, then the inst panel is properly grounded.
A head light switch could be the problem.
However, first I would look at yoru printed circuit board on the back of the inst panel. Look where the plug goes into it, see if there is a 'wire' (on the board...not the harness side) that is not plugged in properly. This would be my first suspision.
Old 11-08-2002, 11:19 AM   #6
Capitol68
Capitol68's Avatar
Are your tail lights working ? could be just a fuse.
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
