06-10-2008, 11:13 PM | #1 | |
PCV vs. Breather.....
Well I found where that burning oil smell was coming from, one of my breathers is leaking from under where the vents are. And my "old know-it-all" neighor told me I should ditch one of my breathers(I have one on each valve cover)and sustitute a PCV instead.
Just wondering what that would do for me?
06-10-2008, 11:21 PM | #2 |
Re: PCV vs. Breather.....
It lets the engine suck in that excess crankcase pressure so it doesn't build up and cause your current leak.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-10-2008, 11:27 PM | #3 | |
Oh, so they are a good thing then....
Aight, Ill pick on up tomorrow.
06-11-2008, 12:37 AM | #4 |
Weldin' it up
i dunno i have two breathers on one side and i have no leaks at all
-Paul- RIP El Jay Dirt is for Racing, Asphalt is for Getting There If need be, send me an e-mail at cbm_racing_90@hotmail.com 1970 Custom/10 LWB 4X4 350/TH350 2003 Silverado 1500 Ext. cab 1974 Kawasaki 175 F7 Enduro 2002 Polaris Edge X 700 |
06-11-2008, 01:00 AM | #5 |
its all about the +6 inches
there is absolutly no good reason to NOT have a PCV system. Yes, it is a smog control item, but it costs no power, and is a great benifit to your engine.
06-11-2008, 01:12 AM | #6 |
yeah, What he said. I have one on my engine. It doesnt need it to operate so when the neighbor kid was installing his engine that seemed to have excessive blow by or high block pressure in his ..... FORD... I robbed my brand new grommet,PCV and hose. Put it on his valve cover and poof no more blowing the dipstick out of his engine. Needless to say he has yet to replace the parts but Mine ran fine without issue for its long trip outside the other day. I will still replace it and always have one on my engine as well.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
06-11-2008, 01:42 AM | #7 | |
I was gonna get one, but it slipped muy mind when I was handing the parts store guy all my money. And the closest parts store is ~30 miles away so it wasnt in my plan to turn around and buy a $4 item if I didnt need one, since I have a bucket full of breathers Ive pulled of my other engines. So I just threw them on as a temporary fix so I can get it going, and forgot all about it until now.
06-11-2008, 01:44 AM | #8 |
Hollister Road Co.
The PVC does serve a purpose. It draws out the gas fumes from the crank case when you flood or the rings don't seal like they used to and the gas passes the rings. One good back fire with fumes in the pan and it will come off promptly, I'm sure you've heard of grenading the pan.
The other purpose is to help seal the rings when running. Vacuum in the crank case is a good thing it actually add HP. |
06-11-2008, 06:20 AM | #9 |
plus the natural bybrouct of combustion hangs out in there as a very corosive gas and becomes acidic. It then contaminates the oil and atacks the metals inside the engine.
06-11-2008, 10:26 AM | #10 |
The breather allows air into the valve train and crankcase. The PCV draws air OUT from the block and is routed to under the carb where the gases are burned in combustion. You need both.
Mine is chopped, has a clutch, and a big block. |
06-11-2008, 03:21 PM | #11 |
i have pretty severe blowby is it ok to put another pcv valve on the other too and then tee the two together
06-11-2008, 04:30 PM | #12 | |
cparman, let your buddies raz you all they want. You have the correct set up. jonnybravo, the only way you can do this and have it work properly, would be 2 PCV valves on one valve cover, and breather/tube to air cleaner on the other. If you just go valve on one side, and valve on the other side with no way to get air in, you will suck the gaskets into the engine. |
12-19-2012, 12:40 PM | #13 | |
JK |
06-11-2008, 03:24 PM | #14 |
The more the better! Better to burn the gases rather than blow off to the environment.
06-11-2008, 03:43 PM | #15 |
sharp as a marble
I have a PCV in the right valve cover, and I plumbed a tube from inside of the air cleaner to a grommet in the left valve cover. This way you have clean ( well cleaner ) air going into your motor. My buds think I think too hard, but the air going into the engine is filtered. If someone on the board will talk to me like I am stupid, and explain the picture thing I will post a pic of this, and my truck
06-12-2008, 12:35 PM | #16 |
Moderator
If for no other reason, you should run PCV to keep oil from blowing all over your engine compartment. It keeps it a whole lot cleaner.
06-12-2008, 12:48 PM | #17 |
What about those of us running a 6 cyl. What would be a correct set up for engines with only one valve cover?
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
06-12-2008, 02:11 PM | #18 | |
You can't see it too well in this photo, but you can see the breather tube on the drivers side of the valve cover going to the air cleaner. I'll assume the PCV is under the air foter towards the rear. |
06-12-2008, 01:12 PM | #19 | |
Packrat
yeah..... I swapped carbs 2 days ago and left the PCV valve not connected to a vac source.... bad juju. the breather tube was puking oil all over!!! redid the connections with all hooked up and it's much happier (and cleaner)
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
12-17-2012, 05:34 PM | #20 |
How do you tell when the PCV is bad? And it move around and still be bad? Mine moved but did not rattle. Made more a thunking noise.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
12-17-2012, 07:14 PM | #21 |
The PCV valve should rattle when you shake it. You can usually clean them out with a little brake parts cleaner if they're not too dirty, but they're also really cheap, so it makes sense to replace it.
12-17-2012, 08:08 PM | #22 |
Ok. Mine did NOT even come close to rattling. It was clunky and has an oily film in it.
12-17-2012, 08:36 PM | #23 |
Young gun
what about the old small blocks 67 and earlier like the 327, you had the oil fill tube in front with a breather on it where was the PCV?
67 SWB Custom "JANE" http://67-72chevytrucks.com/vboard/s...d.php?t=554024 Northwest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ Cameron sparks |
12-17-2012, 10:05 PM | #24 |
They had a road draft system which was evacuated to atmosphere. Basically, the external tube was cut at an angle, as you drove the air rushing past caused a vacuum pulling gases out of the crankcase. There was a baffle in the lifter valley
12-18-2012, 01:19 AM | #25 |
Young gun
So I have a set of Chevy script valve covers, what do I have to do so I don't have to drill holes in them?
