How hard could it be?
![]() Join Date: Apr 2008
Wiring harness question..
I was cleaning and re-wrapping these wires and I broke both glass fuses. They were very brittle and I suspect they were the originals. There are no distinguishing marks on them....does anyone know what size fuse this 1972 harness would take?
Thanks Heres what they look lik now............ |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: Wiring harness question..
Check with Wes at Classic Heartbeat
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 06-11-2008 at 04:52 PM. |
Those are the fuses for ammeter I think. Put new ones in and your gauge will work. I think they are 5a.
No matter where you go, there you are. |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Spray some WD40 in both ends of the connector and carefully get the metal fuse tips out. With a magnifying glass you will be able to read the amp size. I just went through this drill and I cannot remember what amp they are, but I purchased them at Advance Auto.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
The fuses for the ammeter, located on either side of the radiator are 4 amps. I use a snap ring removal tool to remove the metal ends out of the holders.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks for the tips guys.......
![]() Much appreciated Mark |
Gettin By on Gettin By
My origonals were 4 Amp, but a 5 works just fine. I've got 2 5amps in my right now.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
