06-11-2008, 07:55 PM | #1 |
its all about the +6 inches
crazy idea that just might work?
I know I am not the first one to think of this... I'm just wondering if anyone here has TRIED it.
POR-15, painted on headers. Anyone did it? Anyone know a guy who did it? I'll even settle for anyone who knows a guy who knows a guy who did it. |
06-11-2008, 08:31 PM | #2 |
Well, Whoop-dee-do!
Re: crazy idea that just might work?
I know a guy who would try it... or I guess I now know two
Try a test sample on a pipe right off a manifold- my bet is it will start smoking & run off as a liquid. Seen a guy try powder coat- I was there to help him fire it up. Took about 45 seconds and it was all in a puddle on the floor.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
06-11-2008, 08:36 PM | #3 |
I actually went and bought some por 15 for exhaust manifolds at the swap meet. I don't know how different it is from the regular por 15. I haven't had a chance to try it yet.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
06-11-2008, 08:38 PM | #4 |
don't know about the por-15 but mine are powder coated with hi-temp powder coat for about 5 years now, doesn't look bad. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
06-11-2008, 09:51 PM | #5 |
POR-15® is a high performance, versatile aromatic moisture cured polyurethane coating designed for application directly on rusted or seasoned metal surfaces and concrete. It dries to a rock-hard, non-porous finish that does not chip, crack, or peel. Because POR-15® is non-porous, it is an excellent sealer for porous substrates and it completely protects from water, chemicals, salt, and mineral oils. The highly porous characteristics of most substrates and traditional coatings permit harmful elements to penetrate which initiates deterioration. POR-15® is the only coating that is able to protect and extend a surface or structures life expectancy due to its unique non-porous molecular composition. POR-15® is also able to withstand prolonged exposure to temperatures up to 600 degrees Fahrenheit.
http://www.por15.com/CS_DuctWork.asp that what i found that it's good to a temp of 600 f there Andy.
Trueman |
06-11-2008, 10:03 PM | #6 |
so much for that idea.
Funny... I'm always saying most people who have issues with POR are the ones not reading the label. I guess I am 'one of them' now. |
06-11-2008, 10:26 PM | #7 |
i thought you might of been onto somthing. you know the good idea that pops in once in a while.
Trueman Last edited by 463; 06-11-2008 at 10:27 PM. |
06-11-2008, 10:39 PM | #8 |
The Older Generation
Not with POR-15, but I painted part of the exhaust on my 4x4 ATV with some Rust Bullet I had left over from the mower deck. So far it's holding up good....
LockDoc
06-12-2008, 07:48 AM | #9 |
iused por 15 on my camaro headers and it burnt off. I used bbq grill paint and it held up alot better.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
06-12-2008, 08:06 AM | #10 |
Geeeee Longhorn...it would be a real bummer to be driving down the highway when all of a sudden your headers would burst into flames...that would not be good.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-12-2008, 11:02 AM | #11 |
The POR exhaust manifold paint holds up really well on headers, I had some left over from manifolds and mixed it and sprayed on set of headers I have on 327, it looks similar to some of the coatings you get at other places, no flaking or other issues and hs been in place 2 years, I think they have 3 colors to chose from. A 1/2 pint /pint goes a long way.
06-12-2008, 12:42 PM | #12 |
Moderator
The POR 20 works fantastic on headers. They make it in bright aluminum, cast iron gray, and black. Regular POR 15 burns right off.
06-13-2008, 08:46 PM | #13 |
sharp as a marble
I POR15'd may original exhaust manifolds, and they have held up great. Still too dumb to post a pic or I would.
I glass beaded my manifolds, and then used a foam brush to paint the manifolds. I waited until the next day, and I put another coat on them. After I put them back on my truck, I started the truck and ran it for about 15 minutes, and then it was bed time for this old man. The next evening I ran it for about 30 minutes. Then I started driving it and I think they look great. |
06-13-2008, 09:19 PM | #14 |
bummer manifolds don't get real hot... not in comparison to headers anyways.
06-13-2008, 09:24 PM | #15 |
The por 15 I got says it is good up to 1200 degrees. The interesting thing is is says that you should thoroughly clean (sandblast is suggested) the manifolds before coating. This is the exact opposite of regular por 15 that likes rusty surfaces.
Shawn
06-13-2008, 09:31 PM | #16 |
Moderator
It is POR 20 that is used on the manifolds, not POR 15 (same manufacturer, different applications)
06-13-2008, 11:35 PM | #17 |
I went and looked again. The stuff I have is called Black Velvet. It is in fact made by por 15. The only reference to por 20 is in the directions in which they are explaining the thinning instructions for spraying. They reference the black velvet at por 20. I think they must have changed names at some point. It does say it will work on headers.
Shawn
