Old 06-12-2008, 03:44 PM   #1
hollywood68
Bagged the 68' - lower arm questions - 73+ swap, modifying arms
Like many others it seems my front bags rub the lower arms after cutting the SD cups. No matter the reasons I am looking at getting another set of lower arms (either stock or 73+) to cut the stock "pocket" and weld in some tubing. This will stop the rubbing and get a little more drop since the rear is lower than the front.
I have done some searching and have learned that the 73+ arms will work, but am still confused about the exact details (ball joints, different bushings etc). I am running stock spindles and drums, and only want to change lower arms, nothing else.
So far I have found the threads below to be the most helpful
cutting arms...
http://67-72chevytrucks.com/vboard/s...t=control+arms
more cutting arms...
73+ arms
http://67-72chevytrucks.com/vboard/s...d.php?t=256925
&highlight=control+arms
I have a line on some 73+ arms so considering getting those and modifying them. Any help would be GREATLY appreciated.
pic of the truck
hollywood68 is offline   Reply With Quote
Old 06-12-2008, 05:15 PM   #2
bedsled71
bedsled71's Avatar
Re: Bagged the 68' - lower arm questions - 73+ swap, modifying arms
balljoints are different
bedsled71 is offline   Reply With Quote
Old 06-12-2008, 06:35 PM   #3
hollywood68
I have heard they are different but will work in the 68 spindles, is this correct?
Basically need to know what balljoints to use...
Old 06-13-2008, 07:25 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Here is my old thread, & if I am reading what you said correctly it should apply
http://67-72chevytrucks.com/vboard/s...d.php?t=251067
They should bolt on just fine, & if I remember correctly the upper BJs are the different ones... but dont hold me to it lol
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 06-14-2008, 01:38 PM   #5
hollywood68
Thanks for the link, I looked that over and I think I just need to get some arms and start cutting...
Ill post my escapades in this thread when I get the time to make the swap.
Old 06-14-2008, 02:10 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Get after it
Sinister
Killer
