Old 06-15-2008, 07:59 PM   #1
sierragrande71
sierragrande71's Avatar
'67 Steering Wheel help? What am I missing?
I just acquired a '67-'68 steering wheel from my lil bro for free and I have a '67 CST horn button that I want to use for my '69 C-10. What am I missing to make this work. I posted two pics for all of you to lead in the right direction, if you guys and gals would. Thanks
sierragrande71 is offline   Reply With Quote
Old 06-15-2008, 08:34 PM   #2
Re: '67 Steering Wheel help? What am I missing?
All the horn assembly except the button.Three bole,cup,and nylon spring ring,washer.Then,the washer and bolt to hold the wheel on.
That`s a fine looking horn button.
Old 06-15-2008, 09:26 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I think these are what you need. I just happen to have mine apart so I went out and took a picture.
LockDoc
Leon
Old 06-16-2008, 12:06 AM   #4
sierragrande71
Thanks special-K and LockDoc for the help. I now will have to have to find these parts. Will the existing parts in my steering wheel work? I still have the original wheel and column (don't if that matters?) Thanks.
Old 06-16-2008, 09:43 AM   #5
LockDoc
LockDoc's Avatar
Parts should be the same unless one is a tilt.... Be sure to note how the parts come out, especially the flat metal disk. It is not flat, it has a slight dish to it. Also, the metal cup has a notch in it that matches a tab on the rubber part of the horn button, so it has to be installed in a certain position or the horn button will be off center.
LockDoc
Leon
Old 07-19-2008, 06:33 PM   #6
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Can somebody post a picture of them in order but outside the steering wheel?
I think I'm missing a piece too.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 07-19-2008, 07:07 PM   #7
LockDoc
LockDoc's Avatar
Todd
Todd,
The large plastic piece with the spring loaded contact goes under the steering wheel and the contact tower sticks up through a hole in the steering wheel hub. The disk is the first piece to go inside the steering wheel, then the metal cup, then the plastic retainer with the three screws. If you hold the metal cup in your hand and put the retainer down inside it you will see that the bosses on the plastic retainer fit snug inside the holes in the cup. Turn that assembly upside down and put the metal disk on it and you will see that the holes in the disk just fit over the bosses on the retainer also. That is the way it has to go together. It can be tough getting it all lined up down inside the steering wheel and keeping the metal disk in place. If the disk gets out of place and gets pinched between the steering wheel hub and the retainer, either the horn won't honk or it will honk all the time.
This is one of those procedures that is hard to put into words but fairly easy to do so I hope you can follow my rambling....
LockDoc
Leon
Old 07-19-2008, 08:05 PM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
Thats a nice looking horn button...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-19-2008, 08:14 PM   #9
msgross
msgross's Avatar
You also need the horn cap retainer piece that actually holds the button to the silver part inside...
Here it is:
http://www.truckandcarshop.com/trucks60_72/t60_047.html
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-05-2009, 08:07 PM   #10
easyrider
easyrider's Avatar
Do you still have the CST horn button? I broke mine and need one. Thanks
easyrider is offline   Reply With Quote
Old 08-05-2009, 09:57 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
instead of asking for the one he said he was installing on his truck, why not post a want to buy thread over on the parts board?
Old 08-05-2009, 10:02 PM   #12
easyrider
easyrider's Avatar
I did post a want to buy on parts board.
