Old 06-16-2008, 11:44 AM   #1
c10addict
c10addict's Avatar
anybody cut the upper crossmember spring pocket?
Whats happening?? I am looking at ways to get my current 67 project lower in the front... Its bagged with a kp notch in the rear.. I am on the fence about z'ing the frame right now.. I may go that way but at this point not ready to make the cut... I see a lot of guys are cutting the lower control arms apart and welding a cup for the bag to sit lower in.... Has anyone cut the upper side of the crossmember where the plate/bag mount bolts in and move it up higher? Looking at the frame it looks like it should work... I know you can never run a coil spring again but thats not an issue... Thoughts???
Look at the second pic for an Idea of what I mean... (jacked from backyard88's build thread.. Thanks... )
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 06-16-2008, 03:16 PM   #2
SCOTI
SCOTI's Avatar
Re: anybody cut the upper crossmember spring pocket?
I know @ least one board member that did his.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-16-2008, 05:15 PM   #3
98L150
///Relaxed Atmosphere
98L150's Avatar
here is a link to one that has done this.
http://67-72chevytrucks.com/vboard/s...=266234&page=3
I know i should have some pics of others that have done this here in houston and can share soem photos of once i get to my home computer.
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 06-16-2008, 05:23 PM   #4
c10addict
c10addict's Avatar
Thanks! I felt like John Madden on Monday Night Football drawing those lines on the crossmsmber pic..... BOOM!!!
Old 06-16-2008, 05:53 PM   #5
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
There is a guy around here that did it too. The only thing I noticed is that he had alot more negative camber then I did. Just Z it and get it over with.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-16-2008, 07:41 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
Cross member section... No camber change. ...or Z I'm going for the former.
Frizzle Fry is offline   Reply With Quote
Old 06-17-2008, 09:55 AM   #7
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I cut the cups off flush, then plated it and added these upper mounts. [IMG]http://*****************/images/products/mid_Rear_Upper_Bag_Bracket_Dual_Port.jpg[/IMG]
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-18-2008, 05:44 PM   #8
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Just do the Z, you know you want to
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-18-2008, 07:32 PM   #9
98L150
98L150's Avatar
here are somes of what i have on file
72 Suburban
64 Build Thread
Old 06-19-2008, 08:23 AM   #10
c10addict
c10addict's Avatar
Thanks for the pics! Dunno what I would do without the board and the great people on it!!
Old 06-19-2008, 08:22 AM   #11
c10addict
c10addict's Avatar
Im picking up some steel tonight.... Lol... Here we go again! Any pointers??? 2.5 seems to be the norm....
Old 06-19-2008, 12:48 PM   #12
BACKYARD88
BACKYARD88's Avatar
I did 3 to be safe but I'd think 2.5 would work. Although, what's another .5 inch Better safe than sorry
-Mike Owen-
Old 06-19-2008, 01:14 PM   #13
SCOTI
SCOTI's Avatar
That .500" could be the difference between making a new trans tunnel because everything hits or tweaking the exisitng tunnel because one area hits....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2008, 02:21 PM   #14
BACKYARD88
BACKYARD88's Avatar
I def. see where you're coming from. In my case I'm already doing enough cutting on the frame that some extra sheet metal work is no biggie. I also bought a high hump cover just in case
-Mike Owen-
Old 06-19-2008, 02:24 PM   #15
c10addict
c10addict's Avatar
I got me one of them there high hump tunnels on the shelf... Looks like I should go 3 then...
Old 06-19-2008, 02:30 PM   #16
BACKYARD88
BACKYARD88's Avatar
Well, like SCOTI said, it may cause you more work on the tunnel if you do. I don't have much factory stuff on mine anymore(engine mounts etc) so I just made sure I could get the frame down and I'll tackle the rest as I go. I guess it just depends on how much work you're willing to do. If it's a concern for you, mock it up and don't do more than what you need
-Mike Owen-
Old 06-19-2008, 02:50 PM   #17
BACKYARD88
BACKYARD88's Avatar
Don't feel bad, mine was supposed to be a 4/6 static drop when I started
-Mike Owen-
