06-16-2008, 10:54 PM | #1 |
Dualjet 200 carb
Has anyone ever heard or used these carbs. I have a two barrel dualjet 200 and it is driving me nuts. What carbs do you guys use on a standard 350.
50th Anniversary 1968 Chevy C10 Custom LONGBED FLEETSIDE 350 out of a 70 chevy |
06-17-2008, 08:24 AM | #2 |
Re: Dualjet 200 carb
Ill try and give somemore info on it. It looks just like a four barrel rochester Q-j but the back two barrels have a plate that are over them. I thought I could take it off but it is actually one piece. I will try and take some pictures of it after work.
06-17-2008, 09:56 AM | #3 |
I am a Referee of life.
Sounds like swap meet time to me.A used aluminum intake and a Quad should run around $200.00 if you shop.A rebuild kit and then you have something members here can help you tune.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-17-2008, 10:46 AM | #4 |
It's just like a Q-jet without the secondaries. The same tips apply. Make shure the metering rod piston is not stuck. Make shure the float is not soaked & the float level correct.
06-17-2008, 11:14 AM | #5 |
Yeah I will have to tear in an see whats going on with it. I think I might just try a swap meet or something. I just didn't know if any of you guys had even heard or even seen a carb like this.
06-17-2008, 11:48 AM | #6 |
Old Skool Club
I remember them and remember thinking that somebody got cheated on Q-Jet. I am thinking that they were a stop-gap effort at getting some gas mileage out of the mid-70's smoggers, in response to the time in our history when gasoline went up to 60-cents per gallon!!!
Didn't like them.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-19-2008, 11:33 AM | #7 |
I found an article about this carb.
It was introduced in 1976. In 1977 it was put on a pontiac 3.1 V8 and also a 49-state Buick LeSabre. It was funny because they said it supplies good, but not excellent, mixture ratios to engines during operation. They said that it worked best during idle and right off idle. After that they said it leans out. That is just what mine has been doing. Sounds like time for a different carb.
06-20-2008, 10:23 AM | #8 |
If you want a really good 2 barrel carb, try a Holley 500cfm.
