Cereal Killer
2006 5.3 with extras
2006 5.3 (bought as low mileage and believe it) engine with all the accesories. Swapped TB for a new cable drive TB so i could run a 700r4 tranny. Speartech modified harness for stand alone, removed all tranny and emmision crap except front O2 sensors.Speartech also went through the computer and removed all the torque management, all the emission except front O2, removed all tranny wires, included new fuse panel with check engine light and aldl plug. TVmadeEz TV cable kit for LS1 that can be made to work with this combo. Intank fuel pump assembly from tanksinc. 700r4 valve body from tci that holds constant tv pressure(pn 376020 I believe) and TCI deep pan for 700r4. Advance adapters flywheel and shim to run a 700r4 behind 5.3. Lokar TV cable for 700R4. Steel dipstick tube and dipstick for 700R4(Not cheap chrome) Also have motor mount plates to adapt to earlier stlye 3 bolt motor mounts. Everything except the engine is new unused..changed plans and have no use for this stuff. Also have stock truck manifolds and a few other misc parts. One of the coils was damaged by me while hoisting with Kent Moore lift plates so it will need to be replaced. Also have Corvette fuel filter with return to tank and all the GM quick connect to AN6 adapters on the engine manifold and all the on the filter/reg.
There may be more but this is all I can think of right now. I did to get any warranty on the engine when I bought it so I cant offer any warranty to you. The oil in the motor is used and clean. I believe this to be a great engine for a older model swap to get great fuel mileage. Not interested in parting out anything yet. $2500 Located MOntgomery Alabama 36108 Can get any pics you want in a couple days...had small surgery today so the next couple days wond be possible. email mccausey_at_knology_dot_net Thanks Mark
If I dont do it....somebody else will. |
![]() Join Date: Apr 2005
Re: 2006 5.3 with extras
That's a great DEAL!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Cereal Killer
Yea money is tight for a lot of people right now. Forgot to mention Lokar throttle cable, Kent Moore motor lift plates and im sure there is still more I cant think of right now. Perfect swap for much less money than if you were to gather the parts yourself.
It is a great deal, too bad not closer.
Cereal Killer
I also have a takeout 4wd 700r4 of unknown condition that could go with it to sweeten the deal.
Cereal Killer
Forgot to mentio it has Autometer electric temp and oil press senders installed and gauges.
I am interested. PM sent.
Cereal Killer
TCI lockup controller.......what a deal!!
I dont think your going to find a more complete better priced engine swap!
Cereal Killer
pics
Cereal Killer
more
Cereal Killer
more pics
Cereal Killer
comp/harness
67 is sold
Moved to the proper forum.
#15 |
67 is sold
How much for the Vortec cover and the mounting bracket from the top of the intake?
#16 |
Cereal Killer
2500 and it comes with a ton of other stuff
#17 |
67 is sold
DOH
![]() Let me know if you want to sell those two items ![]() |
#18 |
Cereal Killer
Did going into this category kill the views??
#19 |
Cereal Killer
Get yer motor runnin..I dare you to find a better priced more complete motor swap....get new truck fuel mileage for your classic ride!
#20 |
69fatmotor
i could use some of the 700r4 parts if you decide to seperate the stuff and joe is interested in the 5.3. give me a call.
#21 |
Cereal Killer
went by Joes earlier today....his truck looks great with the 5.3 in it...looks like it came from GM that way...thats what you need for your orange truck.
#22 |
Crew Cut
SOLD ! me likey, me take it all.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
#23 |
Cereal Killer
Cool deal Joe...you gonna put it in Brads truck? When do ya want to get it??
