Old 06-21-2008, 12:40 AM   #1
BurnoutNova
BurnoutNova's Avatar
what year dod they stop using the rockwell t-case?
I looked at a "71" gmc K1500 truck for sale today... well the title and owner says its a 71 gmc anyway. The truck had drum brakes, a CS vin beginning and the t-case shifter wa on the left of the 4 speed shifter... so I'm thinking it must be a 69- or older frame and running gear.
I thought they quit using the rockwell t-case in 69, and some 69's got the np205??? are there any pro's to having a rockwell?
thanks
BurnoutNova is offline   Reply With Quote
Old 06-21-2008, 06:38 AM   #2
Re: what year dod they stop using the rockwell t-case?
You`re right about`69 being the last year for the Rockwells "and" a few New Procees` being used,like on Blazer automatics.It`s a good cast,but no advantage at all.Only,the disadvantage of more rare parts.I think it`s an earlier 4wd with a later 2wd body set on it and front axle up under it.
Old 06-22-2008, 11:49 PM   #3
BurnoutNova
im not sure it had a rockwell, but my 69 k20 i used to have had the shifter in the same spot, and it was a rockwell.
i was hoping it would of had the np205 and disc brakes, i probly would have bought it then
Old 06-23-2008, 02:10 AM   #4
CG
BlahBlahBlah
71's also have disk brake front ends. Sounds like something someone has pieced together.
