06-21-2008, 11:02 AM | #1 |
Question for the air bag guys.
I am getting ready to install the compressor and tank for my rear air bags. It is a small compressor and a one gallon tank. The problem is I can't find anywhere to mount it under the bed area. i have a stepside bed with both a blazer tank and a hidden hitch. Inside the frame rails the tank hits the trailing arms. Outside the frame rail and it looks like the steps would hit since it i a narrow bed. Under the frame rail hangs too low. Any ideas? What did you guys do?
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
06-21-2008, 11:39 AM | #2 |
Re: Question for the air bag guys.
Will it fit in between the hitch? Thats where I put it on my suburban.
http://67-72chevytrucks.com/vboard/s...d.php?t=162718 http://67-72chevytrucks.com/vboard/s...d.php?t=162641
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-21-2008, 03:35 PM | #3 |
THanks for the pic. Unfortunately I don't have that much room between the hitch and the tank. It appears that on mine the space in between is smaller, and their is a crossmember in the spot. if I attach it to the crossmember it puts the tank lower than the hidden hitch, almost at the same level as the bottom of the gas tank. I can't put it on top of the brace, not enough room and it would hit the floor of the bed. Thanks for the pics though. Any other ideas?
Shawn
06-21-2008, 05:39 PM | #4 |
Commander Taco Bello
inside of the frame, up front by the t-arm x member? between the frame and the trailing arm.
don't have one to look at right now, but there might be enough room in there. |
06-21-2008, 06:57 PM | #5 |
I have a dumb question. Do air bags give a smoother ride. I have a 4X4 and thinking about putting them on. I would be grateful for any insite. IvelDesigns I heard that there was flooding in Des Moines. Hope you didn't get any of that nasty stuff.
06-21-2008, 07:22 PM | #6 | |
When set-up correctly, they can give a smoother ride. As one board member had stated in another thread . . .... "It's like riding on air" (that one made me chuckle a when I read it).
06-21-2008, 11:13 PM | #7 |
Are you willing to mount to the bottom of the bed floor. Try looking between driveshaft and trailing arm, above the E-Brake mount. I just cut the exhaust out of my 70 step and that is where the muffler was mounted.
I have a see through bed right now (I got to beat out original bed wood), I will look closer in the morning. |
06-22-2008, 09:25 AM | #8 |
Thanks for the post guys. Y'all are thinking the same areas I have been thinking. Beside the trailing arm on the frame doesn't fit, and my mufflers are in the space you were talking about by the trailing arm crossmember. I guess I will have to look at it again when I get the bed on it. I was hoping to get it all plumbed up before putting the bed back on, but It doesn't look like that is going to happen.
Shawn
06-22-2008, 10:13 AM | #9 |
laying low
Shawn I don't know how large the compressor is but can it be mounted outside the frame under the cab? No exhaust issue there.
06-22-2008, 02:14 PM | #10 |
That's where I would try & mount the tank as well.....
