Old 05-08-2002, 12:05 AM   #1
68 with 350 TPI
68 with 350 TPI's Avatar
Exclamation new member needs a little help!!!!
I just got a 68 SB truck with no motor or trans for $500.
I have a IROC-Z with a 350 TPI/700R4 and I plan to put it in the truck.
I need to know what ideas anyone has for running the eletric fuel pump from the tank.
1)Can I get another tank that will fit a eletric pump or do I need to do some custom fabing?
2)I plan to use the aluminum driveshaft from the camaro in the truck....what do I need to do to make it fit?
Thanks and I hope to have some pics of my new baby soon.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 05-08-2002, 02:17 AM   #2
Andy4639
Old member
Andy4639's Avatar
Cool
Check out my pics in my signature. I have installed a 305 ho tpi in my 71. I used a 93 sub. tank in the bed. (42 gal.) It has all the baffels and lines run already for fuel injection, just swap pumps out. you will need a high flow 45psi pump,suburban is only 17psi. I also have seen guy's take there orginal tank out and drill a hole through the bottom of it and have a small box built under the frame with the fuel sender in it with the pump so you can use the factory tank. You could also find a small car tank with fuel injection are buy a new one from a vendor. I also used the 700-R4 out of a 87 camero with corvette up grades with b&m lock up switch and have over 100,000 miles on this set up with no problems, as far as the drive shaft I can't say, I used my two peice shaft and had it cut and rebalanced with new bearings. Sorry for such a long reply. If you need more info e-mail me.
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels
www.geocities.com/chevy71tpi/main.html
www.picturetrail.com/Andy4639
[This message has been edited by Andy4639 (edited May 08, 2002).]
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-08-2002, 03:24 AM   #3
68 with 350 TPI
Post
Thanks for the reply
A few more questions for you though....
Did you use the harness for the engine/pcm from the donner car or did you get a new one from somewhere?
Old 05-08-2002, 04:18 AM   #4
Andy4639
Old member
Andy4639's Avatar
Cool
I used a street & performance harness, because back in 88 when I put the motor in they were about the only people who knew about this stuff. I'm running there V-6 Ferrio computer with no egr valve, knock sensor, I have had no major problems with it except I can't hook up to a computer to trouble shoot anything, just have to use idit light in glove box.
Andy
Old 05-08-2002, 08:37 AM   #5
ebfabman
Post
Andy, why didn't you use the wiring harness from the camaro?
ebfabman is offline   Reply With Quote
Old 05-08-2002, 09:13 AM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Post
You can get an external fuel pump that will work. I mounted mine on the frame rail about 3 feet in front of the fuel tank after I moved it under the bed. It works great. I got mine from Jim's Performance. It was around $120 and that was about as cheap as I could find one. As far as the harness goes, you should be able to use the old one, just get a TPI swappers guide book and it will show you all the wires and what they are for. You may want to delete the EGR and burn off relays. They are not necessary. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer New project
1995 K1500 Sub(Mommas car)
1989 VW Golf(Beater)
Will be the daughters car if she will pay her insurance! Ha!
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 05-08-2002, 02:30 PM   #7
68 with 350 TPI
Post
I was thinking about taking out the stock tank....draining it then drilling a hole and adding a bung to the bottom of it.
Then flush it out and put it back in with a small hole in the floor for the bung to feed through.
Then just adding a in line pump that is gravity feed from the stock tank.
Any ideas on what pump to use?
Old 05-08-2002, 04:16 PM   #8
red71cheyenne
Back in the sticks
Post
You mean the in cab tank? If you do, there is no need to worry about it drawing a suction. The pumps for the tpi are high pressure. You won't have any problem once you get it primed. That was the only problem I experienced. And a hand vaccuum pump cured that. Let us know how it turns out. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-08-2002, 04:48 PM   #9
68 with 350 TPI
Post
Thats what I figured ...(once its primed it would work). But I figured I would ask to be sure.
Do you know of a good high pressure inline pump for a little green?
Thanks for the info.
Old 05-08-2002, 06:17 PM   #10
Andy4639
Old member
Andy4639's Avatar
Cool
When I went to look at the motor it was seating in a guy's garage in the floor with a cracked block. He had the factory wiring but had cut all the connectors off when he pulled it out, it wasn't worth the time to redo, so I bought the s&p stuff, plus like I said there wasn't alot of info back in 88 on transplanting these engine back then.
Andy
