Old 06-28-2008, 05:48 PM   #1
SCOTI
SCOTI's Avatar
Rear AirRide 'Strong Arm' Question
Does anyone have the rear ART trailing arms on their truck? If so, I was curious about the measurement from the air bag pad on top of the arm to the rear end 'saddle' that the rear end sits on.
I would like to know the height difference between the two....
Scot
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-02-2008, 11:19 AM   #2
PipsC10
PipsC10's Avatar
Re: Rear AirRide 'Strong Arm' Question
Scot
I can get you the measurements tonight when I get home if you still need them. Not sure what you mean by the "saddle" or where on the bag plate you want the measurements from.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 07-02-2008, 12:43 PM   #3
SCOTI
SCOTI's Avatar
I want the difference from the pad where the bags sits vs. the pad that the rear housing tubes sit on. So if you put a straight edge on the pad for the rear housing & measured the distance from there down to the pad that the bag sits on (I want to know the height difference between the two).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2008, 06:49 PM   #4
PipsC10
PipsC10's Avatar
OK, I think I got it. I will measure it when I get home and post it tonight. I will also take a photo of what I'm measuring to make sure it's what you need.
Old 07-02-2008, 08:52 PM   #5
SCOTI
SCOTI's Avatar
100% appreciated!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2008, 09:47 PM   #6
PipsC10
PipsC10's Avatar
I hope this is what you needed. Measurement A is 2 1/4 inches and B is 3 3/4 inches. If this is not what you needed, I can take more measurements. I placed a level at the bottom of the bag plate and measured from there to the top of the housing pad from the front and back.
