Found a cluster bezel will fit in my truck?
I saw it in ebay I think It will fit on my '75 is from a '83
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) Last edited by andresco50; 06-30-2008 at 12:43 AM. |
6.0 powered square
Re: Found a cluster bezel will fit in my truck?
it should
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
I believe the wiper and headlight cutouts are different. However I suppose you could "engineer" it to fit.
![]() Join Date: Mar 2006
![]() I think the wiper cutout is a little more to the left on the older versions. I put a '82 or so bezel in my '73 Blazer and while it didnt fit great it did fit. One thing I didnt like is the top of the bezel seemed to stick out. I think the '81 and later dashes were flat (or at least not as angled) across the top of the cluster as the earlier ones.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
unless it,s free you would be happier with the proper one from a 73-80 model truck
yes.. a 73 80 is the correct bezel thanks guys!!!
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
