Old 07-01-2008, 04:03 PM   #1
Sinisterspeed
Sinisterspeed's Avatar
Lowering a TF truck on stock susp.
I am working on my Dads 55 he's on a budget that I pretty much helped him go through pretty fast. I know he wants the truck lowered. I almost had him talked into an IFS from TCI but with the new motor having to be done we are back to square one on the susp. He doesn't not want to do the sub frame (which was my choice for it) he wants to try to lower it with the stock stuff under it.
So, I thought I had seen somewhere that you can flip the front beam on top of the springs and get 5.5 " drop. This would work about perfect since he is after about a 5/3 drop anyway.
Questions:
Anybody done this?
How did you hook up steering afterward?
Any hidden issues I will find trying this?
Tire size you were able to run afterward?
Next issue:
Installing the Freebie 71 Camaro Power Steering box.
I think I can pretty much figure it out but if anyone has done it do you have pictured that might save me some head scratching?
Possibly remember how you hooked it to the stock steering arm?
Last issue:
Rear is most likely like ever other truck I have lowered. Put on top, add blocks until the desired height? If I'm wrong on this stop me now before I get out the torch...
Thanks in advance for any help on these.
[SiN]
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 07-01-2008, 10:13 PM   #2
pugs
pugs's Avatar
Re: Lowering a TF truck on stock susp.
the rear you can do but i dont think i would flip the the front, look around and find a dropped axle
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 07-04-2008, 04:13 AM   #3
55dude
55dude's Avatar
go for the dropped axle in the front. the steering box you want is a toyota 4x4 box, pre 85' the one with solid axle. never seen anyone use a camaro box before.
55dude is offline   Reply With Quote
Old 07-05-2008, 11:34 PM   #4
Sinisterspeed
Thanks for the advice pugs and 55dude. I will look around for that axle.
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
My Longhorn Build
Old 07-08-2008, 01:50 AM   #5
B17CRX
B17CRX's Avatar
here ya go: http://www.classicperform.com/Store/...cks/4754DA.htm
you will need part number 5559da and two 5559datp
-Joel
B17CRX is offline   Reply With Quote
