Old 07-01-2008, 09:49 PM   #1
jcblue
jcblue's Avatar
what happened to my lights?
cant get my head lights to come on.. they were working.. all my dash lights and parking lights still work as well as teh dome light..
thanks in advance
josh
jcblue is offline   Reply With Quote
Old 07-01-2008, 09:53 PM   #2
Jcentsr6
Junior Member
Jcentsr6's Avatar
Re: what happened to my lights?
check the bulbs. I know it sounds stupid..but I work at a dealer and see both bulbs blow at the same time alot.
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 07-01-2008, 10:55 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Couple of problems I've encountered in the past with these trucks. The light switch itself was bad the first time. I just went and got another from the local auto parts store.
The second time wasn't as easy. It was an intermittent (and dangerous) problem. The sucker would all of a sudden go dark while driving down the road.
After checking all the cables, battery, ground and anything I could think of, I found the high/low beam foot switch was defective. Local auto parts store had one also...
68gmsee is offline   Reply With Quote
Old 07-01-2008, 10:57 PM   #4
jcblue
jcblue's Avatar
thanks a bunch.. sounds like some good places to start looking..
Old 07-01-2008, 11:06 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
kick the dimmer switch on and off a few times. If you get any light... even a flicker, replace it.
VERY common, esp in a plow truck.
Old 07-01-2008, 11:10 PM   #6
jcblue
jcblue's Avatar
got nothing from the dimmer switch..
Old 07-01-2008, 11:14 PM   #7
68gmsee
Active Member
68gmsee's Avatar
A good begining.. Try removing the foot switch and bypass it. I believe its just two cables and you could couple them together.
Old 07-02-2008, 01:51 AM   #8
matthufham
see where you don't have voltage with a simple light tester. start at the headlight socket, work your way down the tan or green wire probing the wire every now and then, see where you lose your 12 volts. or if you do have 12 volts at the headlight socket, see that you have a good ground. i bet the headlight switch is good seeing how every other light works, could be a bad ground on the headlights or their power wire has been cut or a connection came loose, possibly bad dimmer too.
see if voltage goes in the dimmer, and out.
matthufham is offline   Reply With Quote
