07-03-2008, 12:10 AM | #1 |
Can't be this easy
I have a 67 Chevy swb frame and a 71 GMC that is going to do a body and disc brake swap onto it. To change the rear end to use my 5 lug 12 bolt spring set up, would I just remove the trailing arm set up and directly swap my leaf set up? Any help is appreciated I just want to see if this idea is even worth the time to attempt.
07-03-2008, 10:34 AM | #2 |
Texas Big Wig
Re: Can't be this easy
07-03-2008, 04:27 PM | #3 |
Those are great directions only problem is I am going the opposite direction coil to leaf
07-03-2008, 08:09 PM | #4 |
Texas Big Wig
You dont have to remove the trailing arm cross member, just unbolt the trailing arms from it
As for the spring perches, I really dont know if the holes are there or not But my question for you is, why not just cut the spring perches of & swap them from axle to axle & save a lot of work ??? Not to mention still having trailing arm suspension, which IMO is better Last edited by Spray-Bomb; 07-03-2008 at 08:12 PM. |
07-03-2008, 11:33 PM | #5 |
I think you are right on the easier part the problem is I want it to look correct even though I am using a Chevy frame on a GMC. There were a few with the coils out there but I don't want people to mentally start shreading the truck when they see it because of the coils. Hell I may be being too anal I don't know. Thanks for the help again it really is appreciated I am getting close to crunch time and have to start making decisions on the direction to take this build quickly.
07-04-2008, 04:14 AM | #6 |
Texas Big Wig
Well if it makes your decision any easier, its easier to run exhaust all the way out the back on a leaf sprung truck
But I like the ride & traction of the trailing arms better... Plus its easier to bag |
