Old 11-10-2002, 11:06 PM   #1
XXL
Seņor Member
XXL's Avatar
Question Fleetside floor dimensions?
I'm contemplating transplanting a steel floor into my stepside bed. Has anyone got a tape measure handy to see how wide the main piece of floor is that goes between the wheel wells?
Thanks,
Kenneth
XXL is offline   Reply With Quote
Old 11-11-2002, 12:08 AM   #2
crazy longhorn
Fabricate till you "puke"
Fleetside , tub to tub? I have 39 1 1/2", & the tubs are stretched 5".......so stock should be 49 1/2. Im guessing, you plan to cut down a fleet floor to use on the step?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-11-2002, 01:46 PM   #3
XXL
Seņor Member
XXL's Avatar
Yep, that's what I was thinking... and 49 1/2 is the magic number. Do you think it will work/look decent/whatever?
Kenneth
Old 11-11-2002, 01:53 PM   #4
crazy longhorn
I think it might work, & should look good. Your front box panel will be 3/4" too tall, but the mount lip can be cut off & refolded. good luck, & let us know how it goes.....
