Old 07-05-2008, 08:51 PM   #1
t&tkennels
t&tkennels's Avatar
New from n.c. , with a question.
Hi, just joined & already have question. Im in the process of building a mild street rod with a '71 c10 long bed.Im currently working on the inside, & just got done with the paint & dash. Before removing the gauge cluster the lights on the gas gauge didnt work but the speedo side did , while restoring the gauge cluster i replaced all the bulbs & hooked up everything i assume correct & now i only have signal light indicator lights & thats it. Could it be the circuit board gone bad. Im on a very tight budget & trying to do all my own work.Thanks!
t&tkennels is offline   Reply With Quote
Old 07-05-2008, 09:25 PM   #2
kyull67
kyull67's Avatar
Re: New from n.c. , with a question.
Welcome! It could be the cicuit board as those can and do go bad. I just recently changed my gauges to white with blue leds and noticed that the bulb sockets only work one way. Try taking them out and rotating them 180 degrees. If that doesn't work check the bulbs themselves(size 194's) and there is also a fuse labeled cluster feed. Try those first and if none of those things work let us no and we'll try to help you out.
kyull67 is offline   Reply With Quote
Old 07-05-2008, 10:41 PM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Welcome from Fuquay! Pics of the truck?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-06-2008, 05:26 PM   #4
t&tkennels
t&tkennels's Avatar
Hi , just checked everything i could think of . Just wondering could it be the headlight switch, although the head lights work fine?. Thanks , i can use all the help i can get!
Old 07-06-2008, 07:04 PM   #5
truckdude239
truckdude239's Avatar
welcome from winston salem,nc
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-06-2008, 08:27 PM   #6
clay68c10
clay68c10's Avatar
It could be the circuit or it could be the headlight switch. If it's the printed circuit, you'll still have light in your heater control. If you don't have light in the heater control or the cluster, then it could be the light switch.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-06-2008, 09:43 PM   #7
Boog
laying low
Boog's Avatar
How about the ground wire?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-07-2008, 05:07 PM   #8
RaceAGMC
RaceAGMC's Avatar
Welome from Charlotte, i'm not much on electrical, hope someone can get u goin.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-07-2008, 09:32 PM   #9
t&tkennels
t&tkennels's Avatar
:Replaced the light switch , still nothing. i also noticed my heater control light & interier light are not working, but they use to. Ibought a test light & checked the fuse panel , & the dash cluster fuse outlet is getting no power. How could this happen when all i did was remove the the gauge cluster.?
Old 07-14-2008, 09:53 PM   #10
t&tkennels
t&tkennels's Avatar
ok got power to my fuse box, interior light working , heater control light working, & power to the circuit board for the gauges ,still no gauge lights, ive rotated the bulbs , still nothing . Maybe the bulbs i have are not correct but they look the same . Please help!
Old 07-14-2008, 10:32 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If the bulbs plugged into the sockets, they are the right ones, or close enough.
Rotating them doesn't matter unless they are LEDs, bulbs work in either direction.
You say you are getting power to the inst panel, did you test the circuit board?
Quick troubleshooting question, does the fuel guage go stupid when you try turning the lights on?
Old 07-15-2008, 12:00 AM   #12
t&tkennels
t&tkennels's Avatar
hi , no the fuel gauge isnt acting funny. I turn on the lights and checked the circuit board by removing one light at a time & checked each one with a test light & had power on them all.How can they light the test light & not the bulbs ? Im thinking of getting a new circuit board , but hate to waste the money & have the same problem. I just cant think of anything else to check. I will grateful for any help !! Its driving me nuts! All i have left is this & the seat & the inside will be done!!!Thanks for any & all help.
Old 07-15-2008, 12:11 AM   #13
dan42
dan42's Avatar
I have the same problem and have had for a while, because I have been too lazy to troubleshoot it, but I replaced: the bulbs, the circuit board, and the light switch. Mine is a '67, but they are the same for the most part. I have also put grounds in the traditional places with no luck so far, but I plan to ground the instrument panel to something that I know is grounded. After paint, quite often you can lose a ground. If that doesn't work, I'll get someone a little smarter than me to at least diagnose it.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 07-15-2008, 10:01 AM   #14
Luvlegs
Luvlegs's Avatar
If there is power on both parts of the printed circuit (lights your test light) - check the bulb holder base - the spots where they contact the printed circuit could have 30+ years of oxidation and need cleaning - simple fix too!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-15-2008, 10:35 AM   #15
michael bustamante
michael bustamante's Avatar
Originally Posted by Luvlegs View Post
If there is power on both part of the printed circuit (lights your test light) - check the bulb holder base - the spots where they contact the printed circuit could have 30+ years of oxidation and need cleaning - simple fix too!
this is what fixed my problem. I had poor ground contact in the socket and had to cean them with contact cleaner and a stiff toothbrush
1967custom
michael bustamante is offline   Reply With Quote
Old 07-15-2008, 04:00 PM   #16
Longhorn Man
seems odd to have lost contacts on 4 points across the board, but not the directionals. It IS possible, and a pencil eraser will clean the points.
Have you inspected the ground side of the curcuit? The panel bolts to the back of the insterment panel and provides the lights with a ground.
The fact that the fuel guage doesn't get stupid says the panel its self is grounded.
Old 07-15-2008, 06:29 PM   #17
t&tkennels
t&tkennels's Avatar
Ive got the dummy light dash , signals light up fine , & the 2 dummy lights come on when i turn on the switch. just cleaned the sockets & still nothing!
Old 07-15-2008, 04:17 PM   #18
steelhorse
steelhorse's Avatar
Welcome from Wilton NC.
steelhorse is offline   Reply With Quote
Old 07-15-2008, 04:44 PM   #19
Woobie
Woobie's Avatar
Sorry, can't help with the problem, but from Greenville.
Paul
1972 c10
2000 FLHTC 126+k miles, so far
1967 BMW r60
2007 Xterra (Wife's ride)
R.I.P. "ESLL"
Woobie is offline   Reply With Quote
Old 07-15-2008, 06:24 PM   #20
t&tkennels
t&tkennels's Avatar
Wow youre right up the the road ! I went to wilton school. Cool!
Old 07-15-2008, 08:55 PM   #21
steelhorse
steelhorse's Avatar
Have you tried hitting it with a really big hammer
Old 07-15-2008, 10:13 PM   #22
t&tkennels
t&tkennels's Avatar
Im gonna give it another try tommorrow , if i cant get em going the hammer may be my next option.
Old 07-16-2008, 10:34 AM   #23
michael bustamante
and duct tape. You can fix ANYTHING with a hammer and duct tape
1967custom
Old 07-16-2008, 11:20 AM   #24
babyJay
Arrived on a Pale Horse
babyJay's Avatar
The metal contacts inside the bulb base can become separated (stretched) and fail to contact the bulb leads correctly. Try using a small flat screwdriver and bending the parts that "squeeze" the bulb, when inserted, closer together.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-16-2008, 10:03 PM   #25
t&tkennels
t&tkennels's Avatar
ok ,just tried that ,still nothing. i have access to a gauge panel out of a 70' it has gauges not the dummy lights i currently have . Is this a pretty easy swap?.
