07-06-2008, 03:49 AM | #1 |
Door sill plate. And new tranny
What are the screws going into? i have two or three that are loose. How do i fix them? And as soon as i finish my vacation in Hawaii im going to pick up my new trans. Its a 700r4 out of a 92 astro van. Lockup converter pretty much base model. What seals should i get just to freshen it up? tia
07-06-2008, 06:47 AM | #2 |
Re: Door sill plate. And new tranny
The retaining screws screw into the edge of the floor and can be seen sticking through underneath. If the floor is solid, the next larger screw diameter will work, usually. If the floor is not solid then a sheet metal repair can be made to fix the problem.
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
07-06-2008, 11:07 PM | #3 |
ok thanks i wasnt sure if it was some type of j-nut or what. how bout the tranny seals though?
07-07-2008, 10:50 AM | #4 |
I've also replaced the sheet metal screws with machine screws and nuts. That works well if the metal has streched too much to get a larger sheetmetal screw to grip.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
