Which Carb.?
I just bought an 86 it has a 305, TH350, 2.73 gears. Needs a cam (Bad Lobe) so I ordered the sum-k1102 262/ 272, Lift .420/ .442. I going to run either a performer or performer air-gap intake. Which carburetor would be the best for fuel economy the Holley 570cfm Street Avenger Carb. or the Edelbrock 1406 600cfm Performer Carb. I would like to get atleast 15mpg. This will be all that is done to the truck. When I get some extra $$ I will add duals with some flowmasters.
Georgia Boy
Re: Which Carb.?
The stock QJet ought to be a great carb for that setup.. they've got great airflow(750-870 cfm) for future mods too..
Re: Which Carb.?
How hard is it to rebuild it? The one on the truck runs like crap. The reason I asked about these two carbs is I would like something that looks better than the Qjet to clean up the engine bay.
#4 | |
Georgia Boy
Re: Which Carb.?
#5 | |
Re: Which Carb.?
Frank
Born and proudly residing in a Red State ! |
Re: Which Carb.?
Could be it's the orginal carb and looks like crap I sure a new one would be better. I'll let you about the cam when I get it put in it will be a couple weeks.
Cruzzzn' Vet
Re: Which Carb.?
Check these guys out for a Qjet
![]() http://www.jetchip.com/JET_Carburetors.asp http://www.smicarburetor.com/ |
#8 | |
Oh,you can't buy that new
![]() Join Date: Apr 2000
Re: Which Carb.?
I wouldn't run either of those carbs for mileage. , but the avenger can be 'tailored' much easier if it's like a typical holley.?
I would spring for some sort of spread bore or have the original redone. Ebay has lots of reman Q-jet carbs on there. Remember that the metal from that cam went all through the engine already so be careful on initial investment into what may be an already hurt piece. flush the oil plenty. Quote:
BTW, the cam selection is great for an otherwise stock 305, but even in that you won't really 'hear' it. it's on a 114* lobe separation.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. Last edited by crossy; 07-06-2008 at 07:53 PM. |
