repo doors
After setting the doors and painting the cab and doors I put the door seals in and now the doors wont even close. I have ground the slot in the hinges and can't get them to work. Anyone have this problem and a cure?
![]() ![]() Join Date: Jul 2002
Re: repo doors
You'll need to tweak the door & latch adjustments a bit again. Adding new rubber always changes the alignment a bit. Unfortunately it is mostly trial and error. Once you get the seals broke in, you may need to tweak things again.
Good luck.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 07-07-2008 at 08:34 AM. |
Re: repo doors
new doors? Does not surprise me. FatBoys 69 and I did a set on his truck and they were HARD, It still needs a bit of alignment. Quality in this area really needs to step up.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Saving 1 truck at a time!
Re: repo doors
Even on original doors when new seals are added you need to readjust. I could barely shut mine once I installed new seals. They are still going to be quite tight and you will have to close them with authority!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
