Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-08-2008, 01:20 PM   #1
71Dragtruck
71Dragtruck's Avatar
It's back and slmost ready!
Well my truck is back from my chassis builder and I've been working on it every night after work till 11:00pm for the last week trying to get it done for this weekend. No time for celebration pics just yet maybe tomorrow night, or Thur. before it goes in the trailer I'll snap a few.
Anyway truck is now 100-125lbs. lighter then last time it was there scaled 4003lbs. with 1/4 tank fuel. last time 4128lbs. with about 2/3 of a tank. The front drag springs settled too much though and couldn't get another pair that day so I'm not running the springs I wanted for some wheels up launches that only looks cool but eats time anyway. Incase anybodys new or didn't see and or care to read last post I made on the upcoming changes they are as follows. Tubular front upper and lower arms (Fat Man some day but not in the budget this year), dual pistion aluminum calipers and QA1 adjustable front drag shocks, 2" drop spindles and new small block springs. Willwood master cylinder, and Willwood 4 pistion discs in the rear. Narrowed Comp Engineering 9" fab housing, Moser aluminum center section, spool, and 35 spline Moser axles. New Comp Engineering 4-link, notched frame rails and QA1 coilovers with a 31x16.5" tire in the rear now. Pro Systems Nitrous Pro IV 1000cfm carb, fed by a Areomotive A1000 pump and A2000 return reg. system, on the carb side and a Areomotive non-return system reg. for the nitrous side. And a Harwood glass cowl hood to cover it all. And that's about it, a couple of changes and a few new parts.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-08-2008, 01:33 PM   #2
djracer
djracer's Avatar
Re: It's back and slmost ready!
Sounds sweet I hope it totes the mail! Can't wait to see the pics!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-08-2008, 11:01 PM   #3
71Dragtruck
Few pics.
Sponsored by:
Hard Candy Customs
Old 07-08-2008, 11:03 PM   #4
71Dragtruck
more
Sponsored by:
Hard Candy Customs
Old 07-08-2008, 11:14 PM   #5
whatnow123
whatnow123's Avatar
Wow, that is awesome!
Can you tell me where you got the adjustable valve for the rear brakes? I like the looks of it.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 07-08-2008, 11:18 PM   #6
71Dragtruck
Thanks, it's a Willwood valve, Summit, Jegs most performance places can get them for you. I'm in Canada got mine from Mopac.
Sponsored by:
Hard Candy Customs
Old 07-08-2008, 11:29 PM   #7
djracer
djracer's Avatar
lookin way sweet! Can't wait to here the new times!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-08-2008, 11:44 PM   #8
71Dragtruck
Thank Dj, saw your motor pics I was lost for words but feel your pain!!
Once I get things sorted out I'll likely go to a 180 shot and hope to see low 10's with that??
Sponsored by:
Hard Candy Customs
Old 09-20-2008, 08:15 AM   #9
67dragtruck
67dragtruck's Avatar
A 180 shot will pick it up more than you think. It should definitely put it in the 9's.
By the way, very nice truck you have there.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 07-08-2008, 11:44 PM   #10
Super73
Super73's Avatar
What control arms are those and where did you find the alum calipers?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-08-2008, 11:52 PM   #11
Couch
Daily Driver
Couch's Avatar
Nice..... can you post up a pic of the rear showing how wide tires are. im looking to fit some bigguns and wanna see if a 32x14.0 will fit on a 12'' wheel with a 8 inch backspacing, from sidewall to sidewall they are 18'' on a 14'' wheel. im hoping going to a 12'' wheel will suck it in some and i can tuck the tire. any help would be greatly appreciated, thanks
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 07-09-2008, 12:02 AM   #12
71Dragtruck
I'll try tomorrow if I remember and have time, still have lots to do if I'm racing this weekend. My tires are 31x16.5 on a 12" rim 7.5 backspacing and I have lots of room, tubs are 1to1-1/2 from the frame rail and I have over a 1" room on the inside and room enough on the outside to go out another 1-2" and still tuck them up. My rear is 6" narrower then the stock 71 rear was
Sponsored by:
Hard Candy Customs
Old 07-08-2008, 11:57 PM   #13
71Dragtruck
I think they are CPP??? I got them from a board member last year. He did tell me what they are but can't remember. The calipers are Howe, and took a bit of work to fit my rims.
http://www.howeracing.com/Braking/In...ton-Double.htm
Sponsored by:
Hard Candy Customs
Old 07-09-2008, 10:16 AM   #14
regan wilson
regan wilson's Avatar
Man that is a clean truck . What lower control arm is that ? How much weight difference from the stock one ? You know Harwood test fitted those hoods on my truck . My friend worked there and he even gave me one but I traded it off to the guy who fixed my steel hood for me . Does yours fit good against the fenders? Mine had a huge gap (you could see the flat edge of the fender seam under the hood)
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 07-09-2008, 11:04 AM   #15
71Dragtruck
Thanks, I think they are CPP??? I got them from a board member last year. He did tell me what they are but can't remember. New front end parts are about 10lbs. lighter so not very much at all, bottom arms are are about the same as the stock, they are alot heavier then they look that's for sure. No gaps on my hood, fits good that way but sticks up alot more then my stock hood, I worked the slots on my hinges to drop it down. Pasenger side still sticks up, but it needs some taken off the edges and the front just haven't done that yet. Besides that the back of the cowl didn't clear my aircleaner and I had to cut it out, must be built more for show I guess.
Sponsored by:
Hard Candy Customs
Old 07-09-2008, 03:27 PM   #16
ripdog28
ripdog28's Avatar
This is a sick set up... im subscribed.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-09-2008, 04:05 PM   #17
nxtruck
nxtruck's Avatar
71,
That truck looks GOOD!! The hood really looks good on it. I wish that Harwood made a hood for the '60-'66s, as I would have bought on from them.
Have you ran it since you put the Pro-Systems carb on it? I'm kinda curious how much difference you'll see with it. What carb was on it before?
The truck really looks good with the lowered stance!!
Let us know when you make some passes with it!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 07-09-2008, 04:13 PM   #18
71Dragtruck
Originally Posted by nxtruck View Post
71,
Thanks, I havent run it with the Pro Systems carb yet, I had a Mighty Demon 850 on it before this. Hope to race this weekend, I'll keep ya posted.
Sponsored by:
Hard Candy Customs
Old 07-09-2008, 11:55 PM   #19
71Dragtruck
Here are a couple of quick pics Couch, sorry they turned out so dark, light was bad.
Sponsored by:
Hard Candy Customs
Old 07-10-2008, 12:02 AM   #20
Super73
Super73's Avatar
I was lookin at these wondering if they might work for me..
http://store.summitracing.com/partde...5&autoview=sku
Old 07-10-2008, 07:59 AM   #21
Super73
Super73's Avatar
Will do.. I'm not sure where to start on the weight reduction first though. So I just bought a game scale that goes up to 550lbs. Since the truck is apart for the most part, I'm going to start weighing things, then divide the weight savings by cost. Figure I'll start with the most cost effective parts..
Old 07-10-2008, 09:57 AM   #22
71Dragtruck
I hear ya, everything left on my list is expensive! I'd like to go to a Fat Man front end with coilovers and a rack, that would save around 200-250lbs. and and would like to go with an aluminum block on my next engine build. I know a glass front clip doors and such would be cheaper, I just like the all steel thing, raises eyebrows at the track, even though I have a glass hood it's not really a race hood.
Sponsored by:
Hard Candy Customs
Old 09-19-2008, 08:34 AM   #23
Marv D
Registered Truck Offender
Marv D's Avatar
LMAO, looking at where your at, nothign your list was ever cheap. BEAUTIFUL truck done first class all the way.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-10-2008, 08:53 AM   #24
Alex1
Alex1's Avatar
Awesome!
Just a little something to think about, it is not legal (NHRA) to mount a fuel pressure regulator on the firewall.
Alex1 is offline   Reply With Quote
Old 07-10-2008, 09:34 AM   #25
71Dragtruck
Originally Posted by Alex1 View Post
Awesome!
The mount can be on the firewall, but it has to be designed to move the reg out min 6" away. It's not so much the firewall persay that they are worried about, the rule is more worded to move it out away from the flexplate/flywheel.
I know where your coming from though, when I first ran my old N2O fuel system I had the reg. mounted direct on the firewall and got busted by tech the first time out. That's when I built a extension to move it out 7" and no problem after that (even though it didn't look any safer to me) they were happy so I said that's much better hey, because getting on the bad side of the tech guys is a loosing battle, seen guys do that before LOL!
Sponsored by:
Hard Candy Customs
