Old 07-08-2008, 01:55 PM   #1
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Question Help! Front drive shaft keeps "falling" out.
OK this is pissing me off. The bolts that bolt the CV yoke to the transfer case keep backing out. Ive tried red, blue and green lock tight. Last time out, I forgot to check the bolts, it looks like two backed all the way out then, of course the remaining two sheared off. I've been using u-joint strap bolts because they are the same fine thread and have the smaller bolt head. Am I missing something?
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 07-08-2008, 02:00 PM   #2
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: Help! Front drive shaft keeps "falling" out.
I had that problem before. I could not get the bolts to hold at all. I wound up cleaning the bolt holes and bolts with simple green and then soap and water. It held for me then. Apparently I got grease in there and it wouldn't hold.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 07-08-2008, 02:32 PM   #3
hdflstf
hdflstf's Avatar
Clean the bolt and the threads with brake parts cleaner. Make sure they are dry - no grease, no oil, clean... Then blue locktite the bolts and torque to spec.
hdflstf is offline   Reply With Quote
Old 07-08-2008, 08:14 PM   #4
jaros44sr
jaros44sr's Avatar
Above advice should work, but you could make some sheetmetal tabs, like used on exhaust manifolds
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-08-2008, 08:17 PM   #5
johnnywagon
It is a greasy mess down there. Simple enough to clean it. Thanks!!
~John
71 Blazer One Ton
59 Belair 2 Door
Old 07-09-2008, 06:09 AM   #6
vtblazer
vtblazer's Avatar
What...no pics?
I like the metal tab idea myself, then you'd be sure.
vtblazer is offline   Reply With Quote
Old 07-09-2008, 11:04 AM   #7
jaros44sr
jaros44sr's Avatar
Do you have to add 10 percent of the torque value when adding a solution of liquid?
SAFETY FIRST
AS usual, off topic
Jim
Old 07-09-2008, 02:19 PM   #8
BIG HEAD
Jonnyw. There Is A Number Of Things That Can Contribute To Your Problem. You Have Already Been Told A Couple Of Things. If Those Dont Work. Check To See If Your Yokes Are Binding Up When You Put Twist On Your Suspention. Looking At Some Of Your Pictures I Bet The U-joint And Yokes Are Binding Causing Stress On The Straps And Bolts. You May Be Able To Do A Little Grinding. Or The More Expensive Route , Bigger Joints. You Probaly Have A 1350 Joint. If So Go To A 1410. I Hope The Info Helps. Looks As Though You Have Fun With Your Ride, I Can Apreciate That, Bighead
BIG HEAD is offline   Reply With Quote
Old 07-09-2008, 07:14 PM   #9
dammitmitchell
the pollock
dammitmitchell's Avatar
i had that issue also i used a bore brush to a 380 pistol on a cleaning rod with my drill, then sijmmplegreen ord driveway cleaner ...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
