![]() Join Date: Feb 2008
Body mount bolt torque
Hey guys, does anyone know if there is a factory torque for the radiator support and body bolts and, what are they? I am closed to installing my cab back on the frame and check alignment again but figure if there is a torque value that would help me out a lot. Thanks in advance.
Re: Body mount bolt torque
Per the Shop Manual, the torque values are: Radiator supports 20 lb/ft
Front cab mounts 50 lb/ft Rear cab mounts 20 lb/ft Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thank you, thoses readings are much lower than I anticipated and I have tighten them to much in the past. This info helps me a lot, Thank you.
