Old 07-11-2008, 10:27 PM   #1
jsatter04
jsatter04's Avatar
gauge problems
I have a 65 chevy 4x4. I am having problems with my gas gauge, it bounces al over the place. The sending unit was replaced and the wires seem to be ok. I'm not sure about the ohms and what not. Need help please!
jsatter04 is offline   Reply With Quote
Old 07-11-2008, 11:00 PM   #2
joe231
joe231's Avatar
Re: gauge problems
have you tried search? there was a thread on here i think
here is one on another forum http://www.chevytalk.org/fusionbb/sh...hp?tid/187447/
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-12-2008, 06:55 AM   #3
harry
harry's Avatar
Re: gauge problems
check out the Q&A section on the autometer website,i saw the same question there today
harry is offline   Reply With Quote
Old 07-12-2008, 11:36 AM   #4
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: gauge problems
jsatter04, it is probably your fuel gauge. Does it jump around when you are sitting still, like when you first turn on the ignition? Or does it jump around while you are traveling? If it does it while sitting still you can check your gauge by removing the center wire to the sending unit and grounding it out and turning on the ignition. The needle should peg all the way to the full side of the gauge with no movement. If the needle jumps around it is probably the gauge but could still be the wiring grounding out some where. Good luck! Also, have you visited the 4X4 forum? I think I have a picture of your truck post in the thread "Lets see how many 60-66 4X4's are out there. Check it out.
66Gilbert is offline   Reply With Quote
