Old 07-15-2008, 10:24 PM   #1
dakman
Replace these yet? (brake pedal bushings)
I've checked the dealer, NAPA, GMC Paul and LMC with no luck. LMC shows the ones for the clutch pedal that rides inside the brake pedal shaft but they are smaller. These ones are for the brake pedal and are between the brake pedal shaft and the shaft it rotates on that attaches it to the bracket. Brake pedal rotates on the outside of the shaft and the clutch rotates on the inside... do I have this right. My truck is a 72 auto.
dakman is offline   Reply With Quote
Old 07-16-2008, 02:02 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Replace these yet? (brake pedal bushings)
Give one of the board vendors a call. I am not sure if these are repoped, but they (board vendors) will.
70rs/ss is offline   Reply With Quote
Old 07-16-2008, 03:06 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
If you can't find a re-pop, I probably have one laying around on a spare brake/clutch setup. My trucks are both auto, and I got a couple brake/clutch setups with some other parts I acquired over the years. I'll check tonight.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
