BAD BOW-Silverado XST
LS1 fans on a BB radiator
Is anyone running LS1 electric fans? How well does the shroud fit? How about LS1 fans on a 454 radiator?
I'm ready to ditch my current dual 14" fans. I need somewthing with a shroud. I could probably make my own shroud. However, I need special tools to bend aluminum metal sheets. I found some LS1 fans on craigslist for $40. I hope they are avaiable. I have another 1100 mile trip next week to challenge the ZZ4. |
Parts and more parts
Re: LS1 fans on a BB radiator
Good Luck
However, if you find that to be a problem, look at the dual electric fans that SPAL sells with their own shroud assemblies. Easy to mount and work great. I have two sets on my different trucks and have not had an overheating problem yet. Summit sells these under the "Be Cool" name. Dual 11" electric fan setup. |
I run ls1 fans on my stock radiator. I have a post with pics somewhere on this board.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
Well, looks like BADBOW is going to get some LS1 fans!! My A/C blew a big cloud of R-134 yesterday. I turned off the A/C and took my Jimmy to work. I drove over to my A/C guytoday. He connects the gauges and pressure was good. We found oil over part of the engine and lines. The pressure switch behind the compressor did its job. I was dreading the worst. Replacing the new lines again. We found the lower fan was not running.
![]() I found a set of LS1 fans on Craigslist for $40!! I'm meeting the guy at 6:45 AM to buy them. I'll spend most of the day install in them. I hope I don't need to drain the coolant. I'll snap a few pictures. I was thinking of upgrading my Jimmy to LS1 fans. Now BADBOW get's them first. pcmcobra, How old is the thread? Did you post the main topic? |
Found the thread!!
http://67-72chevytrucks.com/vboard/s...d.php?t=254187 |
I have some on my 77. All you need is a few custom brackets. I made some that let the fans sit in the lower shroud clips and bolt to the upper radiator support just like the stock shroud does. I also found a place on evilbay selling the correct weather pack pigtails to wire these in.
1977 GMC Sierra Grande |
what are LS1 fans from?
98-02 Camaros and Corvettes. At full power, they move a lot of air!
