07-18-2008, 05:31 AM | #1 |
Red Headed Step Child
Coolant leak
Hey guys.. I've got radiator coolant leaking but I can't figure out where it's coming from. It's dripping off one of the bolts from the transmission pan. the front corner bolt on the drivers side. It shouldn't be coming out of the radiator pan. And the tranny cooling lines are on the passenger side. Where could it be coming from??
"Dinner, the perfect break between work and drunk" -Homer Simpson |
07-18-2008, 07:45 AM | #2 |
Re: Coolant leak
07-18-2008, 07:51 AM | #3 |
Re: Coolant leak
freeze plug?
07-18-2008, 08:45 AM | #4 |
Re: Coolant leak
Get or borrow a pressure tester it will help you find it.It could be a freeze plug or maybe the back of the intake.
07-18-2008, 08:51 AM | #5 | |
Re: Coolant leak
Intake will be done in the d/w. Freeze plugs at the shop. I;m not dropping the tranny in the d/w. Been there done that. not again
07-18-2008, 12:48 PM | #6 |
Re: Coolant leak
I am a mechanic too,so we must think alike
07-18-2008, 08:33 PM | #7 |
its all about the +6 inches
Re: Coolant leak
if it is a freeze plug, it'll be a lower one, probably on the backside of the oil filter.
No need to drop the tranny. If this is the case, I highly recomend popping ALL the lower freeze plugs out and flushing all the rust out of it. There will be a lot there if your plug rusted out. Then replace them all with new bras ones. |
