07-21-2008, 09:03 PM | #1 |
Keepin it old school
Bazooka's 63 build thread.
Seems like its the thing to do around here so I decided to start a build thread for my project.
Its a 63 Chevy C-10. Shortbed fleetside with big window cab. The 350 sbc and 700R4 trans were donated from a 85 Chevy 1/2 ton. The same truck also donated its complete front crossmember along with it's power brakes/steering. The engine is all stock. Truck exhales thru dual flowmaster exhaust. My plans are to give it a 60's custom look... big changes are comming. Follow along if you like.. Last edited by Bazooka; 01-21-2010 at 05:03 AM. Reason: Better Pics |
07-21-2008, 09:04 PM | #2 |
Re: Bazooka's 63 build thread.
Welcome, nice truck! Looks very solid!
01-21-2009, 07:09 PM | #3 |
subscribed..
glad to see another last year wraparound
63 C10 Longstepper -Rusty [temporary name] White/Red theme planned -Scott |
07-21-2008, 09:08 PM | #4 |
Tuned in and dying from the anticipation
CHEVY ONLY |
07-21-2008, 09:10 PM | #5 |
This was my first project on the truck. installing a new summit aluminum radiator (SUM-380324) Thanks Chief..Sorry no before pictures this time. This radiator fits extremly well. Had to modify the angle of lower radiator hose outlet. Had that welded locally. The fan was making contact.. guy I know modified a stock upper bracket to work with the new radiator.
Well here ya go. My first small update. Last edited by Bazooka; 08-15-2009 at 12:36 PM. |
07-21-2008, 10:58 PM | #6 |
nice!
CHEVY ONLY |
07-21-2008, 11:12 PM | #7 |
i love the color and patina of your truck....i wouldn't touch that at all...maybe a worn "Bazooka Kid's Garage" sign on the door....nice job.
07-22-2008, 12:02 PM | #8 |
Hey Y'all!!
Great looking project. We'll all be waiting for the progress reports.
07-22-2008, 12:05 PM | #9 |
sweet truck love it..
08-10-2008, 09:45 PM | #10 |
08-10-2008, 09:13 PM | #11 |
Small update..
Got my new wheels. 15x6 bare Smoothies. I cleaned them with Acetone and sprayed them with Duplicolor high temp gloss black engine paint. Paint works pretty good for this. Second time I have used it on a set of wheels. Im satisfied with how it came out. I am going to get some of those short bullet center caps for the wheels for that vintage look I'm going for.. Tires are 205/75/15 tires with thin whites.. Will get them mounted this coming week probably. Last edited by Bazooka; 08-17-2008 at 08:57 PM. |
08-10-2008, 09:19 PM | #12 |
So it is 5 lug front and 6 lug rear, since you put in the 85 front x-member?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
08-10-2008, 09:25 PM | #13 |
08-10-2008, 09:28 PM | #14 |
cool, have you thought about a fan shroud? It would probably really help with cooling, as it helps pull air through the radiator, instead of just pulling air from all over. Just my $.02 Sweet truck, though!!
08-10-2008, 09:34 PM | #15 |
Yeah, I haven't got to that yet. Was planning on hooking up a electric fan with a temp activated sensor. Runs 185 degrees in 100 degree weather so I havent been in a big hurry.. The temp does rise to about 195 sitting in traffic though so the airflow is probably a little lacking as is.. I have a 180 thermostat in it..
08-10-2008, 10:33 PM | #16 |
PROJECT 7DEUCE
I like the way the truck is now... Where did you get the bullet caps?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-12-2008, 11:00 PM | #17 | |
http://store.summitracing.com/partde...5&autoview=sku the truck looks cool as is but I'm taking it a different direction. It's going to be much improved in my opinion I think you'll like it too EDIT: I just updated the opening post with some better pics of the truck the way I bought it.. Last edited by Bazooka; 08-12-2008 at 11:06 PM. |
08-12-2008, 11:27 PM | #18 |
i love the look of the steelies myself but itd look cool with the bullet caps and nothin else
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
08-12-2008, 11:41 PM | #19 | |
The whole big and little tires/wheels with the nose down attitude just isn't my thing. Plus the wheels that are on the truck right now will not work with the modifications I have planned in the very near future...(too wide) and incorrect offset. There is going to be some MAJOR work done to this thing VERY soon.. Last edited by Bazooka; 08-12-2008 at 11:50 PM. |
08-13-2008, 11:47 AM | #20 |
Nice..
08-13-2008, 06:38 PM | #21 |
Welcome from Kansas City. It looks like you are well on your way.
08-15-2008, 10:15 PM | #22 |
Got the wheels and tires mounted today.. Haven't orderd the center caps yet cause I wanted to order them at the same time I order my drop spindles (save shipping $) and I needed to measure my rotors while I had the wheels off. I am going to be using the DJM 3" spindles. My rotors are the 1.25" units so I can order the cheaper set.. They are $50 cheaper then the ones for the 1.0" rotors.. Whoever lowered this truck just cut the springs like a mad man with stock spindles and there is huge camber and a very bouncy ride.. thats all going to be fixed..
Next on the agenda is to get this puppy laying on the pavement.. I think it will look much better when I get the caps on there and sitting level at ride height.. Last edited by Bazooka; 09-22-2008 at 08:38 PM. |
11-12-2008, 07:50 PM | #23 |
Registered Asphalt Offender
(Quote) Whoever lowered this truck just cut the springs like a mad man with stock spindles and there is huge camber and a very bouncy ride.. thats all going to be fixed.. (End Quote)
That's a sweet looking ride you got there ) Your gonna love the ride once you get rid of those chopped factory springs. Mine only had one coil cut off and rode like it had no suspension. I replaced the coils with 3 inch drop springs and added 2 1/2 drop spindles and Doetsch Tech shocks and it rides better than my '97 Silverado now. Have fun dropping it the right way )
It's not too low unless the tires won't reach the ground anymore! 1963 C10 Short Fleetside Bed Big Back Glass 1974 C10 Short Stepside Bed 1982 S10 Shortbed 350 EFI V8 http://67-72chevytrucks.com/vboard/a...hp?albumid=140 http://www.hubgarage.com/mygarage/MEANlowGREEN http://www.motortopia.com/garage/cars/MEANlowGREEN http://www.myspace.com/jcsmeed Last edited by MEANlowGREEN; 11-12-2008 at 07:53 PM. |
08-15-2008, 10:52 PM | #24 |
cool man..looking good!!!
CHEVY ONLY |
09-15-2008, 07:46 PM | #25 |
Decided to do the engine first before I do anything else. Everything under the hood will be brand new. Already got started on that. I'll post some before and after pics in a few weeks when it's done..
