Got Big Block?
2.5" lift options
I just want a modest 2.5" lift to get the stance just right on my '72. I've never messed with leaf springs so I'm a complete noob when it comes to lifts. Do I want springs all the way around or can I live with blocks in the rear? Should I buy shocks with the kit or get them seperate? This will be a mostly street driven blazer and I don't want to break the bank buying the lift. Is it too much to ask to find a good riding, easy to install, economical lift kit?
Oh, and if anyone wants to help install it, I'll have all the ice cold adult beverages you can drink..... Update: found this kit, is it total junk? http://www.4-wheel-drive-lift-kits.c...on-lift-k.html
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 07-23-2008 at 03:58 PM. Reason: update |
I'm a poor spectator
Re: 2.5" lift options
I think 2 inch would give your blazer a nice stance, i'm planning on going with something similar. That kit is 461 with shocks which I don't think is bad. You will still be unlevel in the rear though about two inches. Contact the complany and find out how hard it would be to swap the rear springs for 4 inch springs and if the cost would be affected.
Oh and it's really easy to do, just get out the breaker bar to get the old bolts off and start spraying them with PB blaster or another penetrating oil now.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
The LuvShack Garage
I am assuming that is yours and you wanna keep the wheel/tire set-up it has right?
Got Big Block?
That's correct.
"Experience is what you get when you didn't get what you wanted." |
Strongman Garage
![]() Join Date: Apr 2000
Do you run a hardtop ever? If not it shouldn't sag much in the rear I was told
You can get a shackle flip for the back to avoid blocks.
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
Its lookin' like a Blazer!
You could always have the springs rearched and bring it up some. Look in the yellow pages under spring.... Great lookin' K5.
Some other choices http://www.topguncustomz.com/Store/products.php?S_ID=65 If I were going through the knuckle bustin' fun of installing a lift I'd go 4". Not to high but you can run 35's on the road and still look good on with what you have now. Last edited by Big J; 07-23-2008 at 05:25 PM. |
Got Big Block?
I'll only run the top when I have to, I'll check on having the springs re-arched too
That's a good kit. Haven't used that exact one, but Tuff Country is personally my favorite.
![]() Join Date: Feb 2000
I'm pleased with the Tuff Country springs I've used in the past. For your intended usage I wouldn't be worried about any problems using blocks in the rear.
If you went with the shackle flip your rear axle is going to move forward a bit and that tends to look odd in the wheel well. A Zero Rate from OffRoad Design will get it back to where you want it but that would add yet another inch of lift. Good luck and keep us posted. Sure is a nice K5.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Future TOTM Winner
Where exactly are you in West Texas?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
I hope we don't have another one from SabinALL
Got Big Block?
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 07-24-2008 at 02:34 PM. |
#13 | |
#14 | |
#15 |
![]() Join Date: Nov 2007
I'm running 5125's on mine. Great ride. Like Jtrux said, they're not cheap....about $85 each. The shocks you choose are just as important as the spring. Lousy shocks will make even the best springs ride terrible.
#16 |
Yeah but i'm sure they're worth it.
