Old 07-23-2008, 06:22 PM   #1
SilveradoDude
I have a short; Need assistance
Well after much consternation, I figured out I have a short but I haven't been able to track it down as of yet. I disconnected the negative battery cable connected the test light to confirm the short. I disconnected all of the fuses/relays at the fusebox one by one but the light stays on. I do not know where to look now. Any help is appreciated.
SilveradoDude is offline   Reply With Quote
Old 07-23-2008, 07:12 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: I have a short; Need assistance
Have you checked the wires going down to the starter? Since it has power going to it all the time, it might be a good place to check too..
Albatrossian is offline   Reply With Quote
Old 07-23-2008, 09:23 PM   #3
SilveradoDude
You're saying disconect the wires at the starter to narrow down the short?
Old 07-23-2008, 10:11 PM   #4
Albatrossian
Georgia Boy
Yessir. Anyplace that has constant power all the time.
Old 07-23-2008, 08:53 PM   #5
72lb4x4
I think I've read suggestions to disconnect the big red wire from the alternator and test again...
72lb4x4 is offline   Reply With Quote
Old 07-23-2008, 09:24 PM   #6
SilveradoDude
I did that.
Old 07-28-2008, 03:22 PM   #7
SilveradoDude
Exclamation Re: I have a short; Need assistance
OK, I have narrowed down the short to the red wires that connect to the starter. On those wires close to the starter there are are two black plastic cylinders one marked 14 the other 16 are these fuses or surge protectors?
Old 07-28-2008, 05:43 PM   #8
Albatrossian
Georgia Boy
They're fuseable links.. there may be a dead short somewhere in there..
Old 07-28-2008, 10:23 PM   #9
SilveradoDude
Old 07-29-2008, 06:36 PM   #10
SilveradoDude
Well I replaced that complete wire from the starter to the junction block and... my test light still indicates a short so I think I need to remove wires from the junction block until I find the real short.
Old 08-03-2008, 01:56 PM   #11
SilveradoDude
I think I finally tracked it down. When I turn the ignition key to "ON" the short shows up.
Old 08-03-2008, 07:33 PM   #12
Albatrossian
Georgia Boy
Hmm.. I'd check any constant 12V source coming to/from the fuse box then..
Old 08-03-2008, 09:21 PM   #13
SilveradoDude
I checked all of the fuses it is the power source that comes to the ignition. Does anyone know which color wire I would look for that powers up when ignition is turned on?
Old 08-03-2008, 09:39 PM   #14
Albatrossian
Georgia Boy
Well, there's more than one.. was this happening before you put the new distributor in?
Old 08-03-2008, 10:16 PM   #15
SilveradoDude
Nope. I don't know if the distributor caused it or I did something while installing but I defiantly have a short somewhere in the ignition wires. Any help is appreciated.
Old 08-03-2008, 10:18 PM   #16
Albatrossian
Georgia Boy
Have you tried putting the old distributor back in to see what happens?
Old 08-04-2008, 06:33 PM   #17
SilveradoDude
I thought about that but the short is there with the distributor completely pulled.
