Old 11-12-2002, 07:22 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Gas tank sending unit?????
Are all years of sending units from 67-72 compatible...i have a 71-72 tank that I want to put in my 68, will the 68 sending unit work and/or fit???? or do I have to have a 71-72 unit???
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 11-13-2002, 07:21 AM   #2
GMCPaul
Thumbs up
Depending upon the tank you may have EEC vent lines to cap off but you can use any 67-72 fuel sender for in cab tank in any 67-72 fuel tank. There can be differences that need overcome such as vent lines or diameter line and type of connection as V-8 and 6 cylinder used different diameter fuel line and connector but you can use a adapter to join them. So the answers yes, but mods may be required.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-13-2002, 01:56 PM   #3
SWINGSAX68
SWINGSAX68's Avatar
ok
Paul,
now, the Vin number will tell me if the fitting from the fuel line to the sending unit is for a 6 cylinder or V8.....is that fitting universal for either 6's or V8's.
If i do find that it is was originally a 6.....do I need to get a sending unit for a 6????
-Roger
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
