Old 11-12-2002, 07:36 PM   #1
6772king
6772king's Avatar
Question ac help
i know i dont need it now but hopefully someday i have a 6772 with working air. my question conserns the vac hoses could anyone give me some help on routing from the canister on the side of the heater box then to the switch then T of and go to each one of the vac actuaters????????????? that is where i get lost and what about the heater valve what controles it,in pics it look like vac but where does it come from and is the valve just for shuting the heat of when you running the ac any help would be greatly apperciated thank's sean
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 11-12-2002, 07:52 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
All directions are looking down and facing the dash, driver's side is the left. Line from the reservoir (right side) goes to the right port of the vacuum switch on the control head.
From the center port the line goes to the door diaphragm at the passenger's feet, when all the levers are to the left this vent door will open.
There is a tee in this line, which goes to the outside air diaphragm on the firewall, passenger side in the engine compartment above the heater. This controls the fresh air that goes in through the heater/ a-c unit.
From the left port on the control head vacuum switch the line goes to the water valve, which opens when vacuum is applied. This valve is in the supply side to the heater, where the hose turns the corner at the fender and goes back to the heater.
This is all shown on page 1a-32 of the factory shop manual, a tool well worth the ~$30 investment.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-13-2002, 07:34 AM   #3
GMCPaul
Thumbs up
Here you go this is what you need
Thats out of the Factory service manual. They are a wealth of information on everything on these trucks.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-13-2002, 08:29 PM   #4
6772king
6772king's Avatar
thanks alot fred and gmc paul one other question ????? the vac controls that i have only have 2 ports does that mean i didnt have the heater shut off valve again thank you sean
Old 11-14-2002, 03:13 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
I can't answer that one. If you don't get another response, come to GMC Paul's web page and ask him there.
Fred
Old 11-14-2002, 05:26 AM   #6
GMCPaul
The only difference on your 67 is the fact that there is no vacuum line for a water valve. So just disregard connection shown in picture for it, otherwise everything is the same.
GMCPaul
Old 11-14-2002, 05:47 AM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
Ah...that explains that useless canister on my truck. I removed it and put the vacuum switch for my 700R4 there...it'd long been disconnected from anything other than engine vacuum.
My A/C works, but it is a bit of a mess...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 11-14-2002, 06:27 PM   #8
6772king
6772king's Avatar
thanks alot guy's that should get me going again!!!
