Old 07-23-2008, 11:06 PM   #1
andresco50
andresco50's Avatar
Ignition lock cylinder removal???
I bought a new cylinder for my switch but I donīt know how to install it.. removing the steering wheel??
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 07-23-2008, 11:31 PM   #2
85SBC400
Re: Ignition lock cylinder removal???
i'm glad you brought this up, i need help with this as well.......
come on guys, knock out two birds with one stone here lol.
85SBC400 is offline   Reply With Quote
Old 07-23-2008, 11:42 PM   #3
Square84
I don't think these pills work
Square84's Avatar
Go To Parts Store Rent Steering Wheel Puller And Lock Plate Tool Take Both Off The Remove The 2 Screws Holding The Turn Signal Switch In Place Then The Is 1 Phillips Screw That Holds The Lock Cylinder Once You Remove It The Lock Cylinder Pulls Out New One Goes In The Reverse All Prev. Steps
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 07-24-2008, 12:00 AM   #4
85SBC400
Old 07-23-2008, 11:59 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if you dont want to rent a lock plate tool its easy to make one using a piece of flat stock, a couple of bolts and four nuts
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-24-2008, 09:49 AM   #6
andresco50
andresco50's Avatar
I'll try to make one..
2001 silverado 2wd
2003 silverado 4wd
Old 07-24-2008, 11:28 AM   #7
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I borrowed both tools from Autozone and changed it right in thier lot. Then walked right back in and got my deposit $ Back.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-24-2008, 03:32 PM   #8
gafiredog
doesn't the removal differ some between 73-80 and 81-87 ? i have been told there was some difference. i don't know.
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 07-24-2008, 07:22 PM   #9
OJOE
Crew Cut
OJOE's Avatar
the older ones has a pin you push in with a screwdriver in place of the set pin
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 07-24-2008, 07:56 PM   #10
spr85gmc
spr85gmc's Avatar
thats what i was thinking i have done both if its your 1st time then just be patient its not as hard as it seems. the 1st time i did mine was in my school parking lot at 11;45pm so yea it was a b!tch
spr85gmc is offline   Reply With Quote
Old 07-24-2008, 09:05 PM   #11
andresco50
andresco50's Avatar
Help heeeeelp me guys!!!!! I canīt remove the old cylinder check the pic!!!
2001 silverado 2wd
2003 silverado 4wd
Old 07-24-2008, 10:56 PM   #12
spr85gmc
spr85gmc's Avatar
pin hole should bee on the lower outter side (black side) and im pretty sure you need a key to get it out
Old 07-24-2008, 11:16 PM   #13
andresco50
andresco50's Avatar
I canīt find it..... maybe I have to drill a hole here
2001 silverado 2wd
2003 silverado 4wd
Old 07-25-2008, 12:12 AM   #14
f.monroe
f.monroe's Avatar
If you removed the correct screw , try turning the ignition to the run position and see if it comes out . I cant see but if there is a slot where my arrow is , Take a screwdriver and press the small latch where the arrow is pointing if there is a vertical opening . If it doesnt come out the first time , turn the key to run and try again . The torx screw should have had a threaded portion and a smooth shouldered section if it was the correct screw .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-25-2008, 12:28 AM   #15
85SBC400
thats how mine was (torx screw) and thats all it took and the key cylinder basically fell out in my hands.
i bet his is the one you have to use the screwdriver to get out with. i've never seen that one personally so i dont know the how to for that one.
Old 07-25-2008, 12:38 AM   #16
andresco50
andresco50's Avatar
Frank
Ok guys finally!!! I made a slot with the screw driver to press the latch.. thanks... now I need a diagram to install everything again
2001 silverado 2wd
2003 silverado 4wd
