11-12-2002, 09:25 PM | #1 |
HELP...Broken Intake Bolt
I was swapping Intakes and went to take old one off, put socket on the bolt, started taking loose and the head snapped off. I have about 1/4 inch of bolt sticking out. I tried vise grips and that didn't budge it. Any other ideas? Thanks
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1 RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall '05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD |
11-12-2002, 09:32 PM | #2 |
You could try some penatrating oil or try heating it up. If that don't work, Get a set of easy outs. You can buy just the particular size you need or buy a set. They are very handy.
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
11-12-2002, 09:36 PM | #3 |
go get a can of pb blaster very very good stuff makes wd40 look terrible. soak it down then try the vise grips again. or go get urself a stud remover socket. u could also try a left handed drill bit
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-12-2002, 09:53 PM | #4 |
PB Blaster!, that with a little heat should get it moving again.
There haven't been to many GM's I haven't removed using that method. Mainly because the bolts that break are 1 of the 4 near the thermostat and seize from the coolant corrosion. PB will cut right through that type of corrosion. the heat will make it work a bit faster while expanding the head slightly. basicly do what cableguy recommended and add heat. (just a small propane bottle will do) |
11-12-2002, 10:27 PM | #5 |
What is PB?
11-12-2002, 10:28 PM | #6 |
11-12-2002, 10:30 PM | #7 |
pb blaster is an excellent penetrating lube that is by far better than almost anythign else out there. i havent found anything thats better . i know that stuff has saved me hours of fighting with bolts. stuff that i let soak in wd40 for days and still wouldnt come loos pb blaster had it free in 10 minutes or so and thats not exxageration
11-12-2002, 10:31 PM | #8 |
d@mn piston ya beat me to it
11-12-2002, 10:32 PM | #9 |
lol I picked the lazy way...
11-13-2002, 12:17 AM | #10 |
Where can I buy this in Canada?
11-13-2002, 12:21 AM | #11 |
have no clue about canada but here in america every auto parts store known carries it
11-13-2002, 01:03 AM | #12 |
Thanks guys I will go get me some pb blaster in the morning. Piston got it the broken bolt is the first one on the passenger side.
11-13-2002, 10:54 PM | #13 |
Thanks for all the help. The PB Blaster worked like a champ. Now I can finish swapping my intake. Thanks again guys.
11-14-2002, 01:58 AM | #14 | |
PB is the way to go, NAPA stores have the stuff, use it pretty much everyday around 4 bucks a can, WD40 is same as using water |
11-14-2002, 08:31 AM | #15 | |
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
11-14-2002, 01:44 PM | #16 |
L.E.D. Tail lights, Baby!
EZ-outs
IF you get an easy out, and use it:
DON"T BREAK IT!!! YOu think the bolts are tough to get out... Ezouts become an oxymoron if you break them.
Prov 3:5-8 "Hook 'em" L.E.D. Taillights for sale NOW!!! If interested, visit: www.earlyclassic.com or our website: www.jmcled.com All 67-72 GM Taillights are on sale untill 5 p.m. on Dec 15th, with Guaranteed Christmas delivery! joel.mcwaters@jmcled.com |
