Careful, they attack...
Anyone have a turbo or twin turbo setup? want to see pics of turbos.
I was thinking of maybe a turbo, maybe a twin turbo. Just to be different. would look bad a$$!! Anyone out there have a setup like that and would like to share pics.
Thanks Jason |
I have a turbo on my 4.3 in my typhoon. Came factory, even though I have modified it from factory, and is going under extensive modifications as we speak.
I was always a big v8 rumpity rump kindof guy, until I got into turbo stuff. Had someone suggest I put turbos on another project I had at one time, I just discounted it as complex for very little gain. Was I wrong. I am a turbo freak now. For example on my STOCK typhoon, on the chassis dyno I put to rear tires, 313hp and 450ft lbs of torque @ ~3500 rpm. Turbos make lots of power and torque at low rpm. The motor itself doesn't have to be very special either, just strong. A buddy in Canada recently built a 4.3, stock block, crank 4 bolt splayed caps) stock vortec heads, stainless valves, very little porting just cleanup, stock exhaust manifolds, stock computer, stock intake, etc etc. ~$3500 into it. On the chassis dyno when they were doing the final tuning, the tires were slipping ~25% by best guesses, and he made 590ish hp @ ~4k rpm, and torque was 600 range if I remeber right. Truck ended up running a 10.7 in quarter, and he drives it to work. (www.turbogm.com if you want to see video of run) The biggest thing about turbos, is the fuel injection. In my opinion turbos and carbs don't mix well. Once you are not scared to get into fuel injection, turbos are just a matter of a few more bends on the exhaust, and up to double the power. If you want some pics of 4.3 setup let me know, or some suggestions email me jeff@nwstp.com
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
I saw a guy on hot rod power tour with a twin turbo 1st gen camaro, carburated. It was a pretty neat set up. I talked to the guy for quite some time.
Modern turbo set ups with computers and fuel injection are a lot more liveable for daily drivers though. |
L.E.D. Freak
ty1295 ! Man I envy you! I want a Ty/Sy so bad I can taste it!
But heres the place to call and ask about turbos for our trucks check this picture 1200hp twin turbo 1972 Chevy 2wd Blazer ![]() ![]()
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
I like the pic of the twin turbo Blazer. I wonder if it could be done with a single or do V8's like twin better? I noticed the heater box had been removed to make room for the second turbo, I would like to keep mine if I could. Also, what kind of turbos are best for V8's, ie. make and A/R. I bet I could get them off ebay and since I have to fab the rest I could maybe save a couple bucks. Second thought is could I use turbos with a TPI system. I was thinking of going TPI on my 327 w/vortec heads, and then I had the turbo idea. Would be cool to do both, but I bet it would get $$$. I just want something a little different form everyone else. I hate doing the same as everyone. It's going to be custom, so I want it to be mine, not just like somebody elses. Keep the ideas coming, I love the info.
Thanks guys Jason |
Do it well or don't do it
There is no A/C on that truck, to me that's a no no. Got to have A/C or I won't ride in it or drive it. I put A/C on everything I drive. I even had A/C on a California Bug I built.
Try to be the person your dog thinks you are. Excellent paint and body site: http://www.autobody101.com/ Visit my Web Site http://home.attbi.com/~agfosteriii |
GUITARMAN,
If you look under the pass air filter you can see the a/c compressor. ![]()
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
The oldair AC unit has the heater and AC all in one box under the dash, allowing for a smooth firewall.
69 SWB LT1/4L60E www.classicplace.com |
#9 | |
Seņor Member
I'm tired of typing now ![]() Kenneth
By god you're right there is A/C on that beautiful truck!
So.... I am right in thinking I could use two smaller (ie. 4cyl) turbos or one big one. The smaller ones seem easy to find. Just look ing the junkyard for a turbo coupe, or a old eagle. I would have to fab up the duct work and all. Is there any trick to where you put the turbos? Do they have to be in a certain orientation? I thinkI really like the turbo idea. Just need to get the money and time.
buy the book maximum boost.
More to turbos than just throwing some that are laying around on. Gets into airflow, etc. The shaft of turbo should be parrell to ground, per some data I have directly from Garrett on turbo project they have donated turbos to me for. Basically, you are looking for air density... which is pressure and tempurature.. you need both. 1 turbo or 2, just depends on packaging, what goals are, and what look you want. Most think twin is faster, but that is not the case.
Thanks for the info.
I am aware there is a lot more to it than just slapping in a couple turbos, I just wnt to get a feeling for everyones opinions. I am new to the idea, and want to hear what works and what doesn't. I would hate to spend a ton of money and have it not work like I want. I think I will get a book or two about it. I like to be informed before I get into anything. I will have it all planned out before I buy anything. Thanks for all the help, keep it coming! Jason |
#14 | |
Seņor Member
Corky Bell, the author of Maximum Boost knows his stuff. He helped me on several projects including a fuel-injected turbo bike before anybody had a kit. He's semi-pseudo-retired but he still tinkers... but for those of you who have been to his shop in Dallas, he moved to San Antonio around 1995 or so. As for which turbos to select, you need to work from the other direction... decide what you want the motor to do, determine what kind of cfm it will take to do it, then size your turbo(s) from there. If you go the "transplant" route and just pick a turbo because it's a good price and it doesn't happen to be sized right for your application, you'll regret it. Kenneth
#15 |
someday
![]() Join Date: Dec 2001
if you are looking for some info on turbo setups go to www.thirdgen.org and check out the power adder forum not trucks but man some sweet setups there
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
#16 |
14.1 @ 96MPH
I know I always post this when someone asks about turbos, but still...
![]() http://www.hotrod.com/editorial/arti...=text&id=42798 Read the article...even though it's a Ford, it's still good info on turbocharging a V8. Plumbing would actually probably be the easiest if you had a dual-throttlebody setup, but I don't think they've ever made one (okay, a GOOD one, I just thought of the Crossfire ![]()
Project1970 - LS1 Swap Complete! ![]() |
#17 |
its all about the +6 inches
Gewt a hold of a member named PRO TRUCKS... he is in the begining stages of doing this. He done looked into it, then bought it all.
Oh, and his will be run on propain! |
#18 |
That turbo motor is an awesome looking set up. Anyone know where you can get that stainless tubing bought and bent at?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#19 |
Burns stainless, do a search on google
I have another site on one of my computers, not at it right now. Similar stuff, but cheaper. As mentioned a single CAN have more spool, but with Fuel injection you can do things with fuel and timing to make this somewhat minimal. Another note to think about, turbos and automatics are a good pair. Sticks add more issues with spool...FYI although there are some solutions with rev limiters, blow off valves, etc. Not sure I like them though.
#20 | |
![]() Join Date: Aug 2001
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
#21 | |
14.1 @ 96MPH
#22 |
SKINNY TIRES RULE!
My dad designed turbos for Garrett for 23 years. He designed the turbos for many passenger cars in the 70's and 80's including the SVO Mustang, Renault R5 and the Buick Grand National. We always had turbo cars around the house and most of his friends had turbo cars. One of the fastest cars I have ever been in was Ak Miller's Turbo Capri. It was running a Boss 351 with a single turbo rated around 900 HP. You can put a single turbo on an V8 without any problems. There are several companys that sell kits for single or double turbos. My dad knew several of the guys in this company; http://www.innovativeturbo.com/
The Cyclones and Typhoons are basically the same engine as the GN but in a smaller, lighter vehicle. We had the prototype GN at our house when I was a kid. I learned to drive on my father's turbocharged pinto. It was a '72 runabout with a watercooled SVO 2.3L engine. Quick and light! When he sold the car a couple of years back, the guy who bought it rapped it around a tree within hours of completing the sale. There has been a lot of developments since my dad was involved in the turbo industry in the mid 80's, but it is still a great way to add efficient horsepower. Here is a twin turbo setup that I found on truckworld.com ![]()
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#23 | |
NOT TRUE!!! The only thing the same is they both have turbo's Buick Syclone/Typhoon (spelled with S not C) 3.8L Buick 4.3L Chevy 200r4 700r4 no distributor distrubutor Garrett turbo Mitsubishi ~3500 car #3300 Sy, #3800 Ty 2wd All Wheel Drive Sorry, the syty people are a little sore over the GMC with a buick debate. It is NOWHERE near the same, lots of misconceptions. The only tie is, the first s-10 had a buick 3.8 in it, GM employee did it, GM was interested, it went from there. NO FACTORY SyTY ever had a Buick motor. I have many more details if you need more proof. Jeff
#24 |
SKINNY TIRES RULE!
I stand corrected. We left LA before they produced the Syclone. They were still producing the GN. I guess I always thought that the engines were basically the same. I guess that is one reason the Syclones were quicker.
#25 |
here's a page about this guys turbo build up
http://www.bmrfabrication.com/Buildup1.htm sounds like quite a bit of trouble. The TPI setup (in stock form) doesn't flow real well. An LT1 intake set up would flow better and make more power in my opinion. |
