07-30-2008, 11:11 AM | #1 |
Cruzzzn' Vet
Plug Wires
Have an 83 with the 305 slug , looking for a set of plug wires that go over the heads instead of under, looked at both Jegs and Summit and not sure which ones would work the best, looking for suggestions
07-30-2008, 11:57 AM | #2 |
Re: Plug Wires
You could always buy a kit to make your own. Ive ordered several sets from an Ebay seller with the store name White Performance. The kits come with 8.5mm wires and were east to cut and assemble, even for someone with as little experience as me. I put a set of his wires and HEI dist. on the '73 Blazer I had and it ran MUCH better afterward. Ive got that same setup going on the 350 that is replacing my 305 this weekend.
1986 C10 - LWB, 305/700r4, posi, vortec heads Last edited by BowTieOgre; 07-30-2008 at 11:58 AM. |
07-30-2008, 12:07 PM | #3 |
www.73-87chevytrucks.com
Re: Plug Wires
You can get cut to fit wires and route them the way you want.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
07-30-2008, 02:34 PM | #4 |
Cruzzzn' Vet
Re: Plug Wires
Thanks guys
07-30-2008, 03:00 PM | #5 |
Re: Plug Wires
I like the Taylor, cut-to-fit sets.
Cut to fit: http://store.summitracing.com/partde...5&autoview=sku
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 07-30-2008 at 03:09 PM. |
07-30-2008, 03:22 PM | #6 | |
Re: Plug Wires
- Greg |
07-30-2008, 03:58 PM | #7 |
Parts and more parts
Re: Plug Wires
I would either go with the Taylor kit or a set of MSD 8 MM wires. What one wants to achieve is the most spark possible to the plug. The lower the resistance in the plug wire, the more HP you can get inthe cylinder. I have the MSD wires on the DD and a set of Taylors on my 385 stroker motor. I like both brands as a good performance wire.
I would say that you should not go to a local outlet and just buy ANY OLD set of wires, the quality can be questionable. |
07-30-2008, 05:18 PM | #8 |
Re: Plug Wires
Here are a few pics of the set I installed (I started out going over the valve covers but decided to go beside them) and a LINK to the seller. If I wasnt on a shoestring budget I might have gone with some MSD wires but these work great and so is the price.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
07-30-2008, 05:31 PM | #9 |
Right turn Clyde
Re: Plug Wires
How do you plan to run your fuel line to the carb?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
07-30-2008, 05:52 PM | #10 |
Re: Plug Wires
Im going to secure the inline filter in the space previously occupied by the air pump and route the hose up and over the A/C delete pulley body to the carb.
1986 C10 - LWB, 305/700r4, posi, vortec heads Last edited by BowTieOgre; 07-30-2008 at 05:54 PM. |
07-30-2008, 07:52 PM | #11 |
Re: Plug Wires
check this on ebay man Item number: 370061060104
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
