Straight jacket required
What carb?
I've got a 450HP 396BBC, what would be a good carb for this? I thought maybe a quadrajet, but don't know the minimum size. I would like a good street carb with electric choke and something I don't have to adjust alot. Thanks in advance for any tips. What are ya'll using-name brand, part numbers, etc would help.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Re: What carb?
peak rpm of the cam or point of shift will help alot..
Re: What carb?
1600-5800rpm
Re: What carb?
![]() Join Date: Jul 2008
Re: What carb?
street only?
Built chevy tuff! ![]() |
Re: What carb?
I have enough for both street and strip, maybe I'll go with the Edelbrock AVS 800.
Re: What carb?
You could go with a quad but electric chokes all hell if they are'nt right and thats all of them ,Why not just put a manual choke on it,you could put it under the dash where you can't see it if you wanted to,but to get your power out of it its a 4 corner carb that has to be worked on a little,BG demon, Holley
Re: What carb?
I like a 650 double pumper for street strip applications.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: What carb?
Yeah that should be plenty his cam specs were real streetable,but its still gonna like the pumps,I think they said stock converter which I would not do just to keep it from loading up in traffic!
Re: What carb?
I've got a 2800-3200 stall in a HD th400. So a 650 double pumper is plenty??? I thought I would have to go larger.
Re: What carb?
Mind you, I have head a little head work done(cast) and the crank shaved .010~~ 1.71 roller tip rockers, Edelbrock RPM air gap intake and .30 over on the 396(402)
Re: What carb?
You should be,but you have to tune them a little but you can jet it up as you need.You could call holley to see what cfm they recomend you also need to figure your VE percent out
