![]() Join Date: Mar 2006
Tilt Column Signal Lever
I did a quick search and didnt find the exact info I needed. Ive got a tilt column out of an '80 that was shipped to me with the levers detached and Im wondering how to reattach the cruise/signal lever.
Thanks Kris
1986 C10 - LWB, 305/700r4, posi, vortec heads |
Re: Tilt Column Signal Lever
With the wheel off. Remove the lock-plate. You'll want a lock plate tool. Worth the money to avoid the 2 screwdriver snap-ring drama. You'll see right where to attach the lever. Just remember to thread your cruise wire down thru the column and plug it in.
Re-assemble. - Dave I'm serious about the lock plate tool!!
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club Last edited by wedgemon; 08-01-2008 at 11:15 AM. |
Thanks for the info Dave.
I picked up the tool at the store and had it fixed up in about 5 minutes.
BTO -
That tool almost makes you WANT to work on the column! Glad it was so easy. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Im not sure of the brand but it was a lock plate removal tool from the local parts store...around $20.
Parts and more parts
Buy one, you will use more than once in your life. Mine fits many different column threads and sizes.
HF = Harbor Freight (discount "chinese" made tools) good when your in a pinch!
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
I made my own lock plate remover check this... and here's a forum for GM tilt steering removal....
http://www.buickperformance.com/tilt...lumnwobble.htm
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
#11 | |
Thanks! That is an awesome post for the column teardown and rebuild
