Old 08-02-2008, 11:43 AM   #1
low900rr
New here and need suggestions.
Had a 66 last year and just got a 64 project to start on. The new truck has a 283 and 3 speed manual that i wanna upgrade to a turbo 350 automatic. Im wondering if the th350 will fit in the tunnel or do I need to do some cutting??? The column in it is bad and im wondering what vehicle is a good doner for a tilt column??? thanks for any input and heres a pic of my old 66.
low900rr is offline   Reply With Quote
Old 08-02-2008, 11:51 AM   #2
originalJD
James
originalJD's Avatar
Re: New here and need suggestions.
Very nice truck! I like it alot. I don't beleive you will have any trouble get a 350TH to fit. You may have to modify your linkage a little. As for a column, I've seen many different year models used. I beleive you can use columns out of trucks all the way up to 95 or 96. Good luck on your project.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 08-02-2008, 11:52 AM   #3
originalJD
James
originalJD's Avatar
I have a 92 GMC I will be useing the column out of once I get to that point.
Old 08-02-2008, 11:57 AM   #4
originalJD
James
originalJD's Avatar
Oh, and welcome to the site. I'm sure you'll like it here and find it very useful too. I have got a 66 myself. I love these old trucks.
Old 08-02-2008, 12:23 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
We need pictures of the new 64 truck now. The 350 will fit and you can use a column from a 70's to 1980 van or a 72 chevy truck if you can find one. Here is a van column I used in my truck and has been replaced by a new one because this one was a bit sloppy.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-02-2008, 09:56 PM   #6
Chevy Fleetside
I put the new column in and today I put in my new steering box and hooked up the steering shaft. I used one out of a 70's truck and cut the factory connection and used my u joint. It is a 36 spline on one end for the van column and a DD on the other end. Also the whole suspension is from a 75 chevy truck. The control arms bolt up to the 65 crossmember.
Old 08-03-2008, 10:02 AM   #7
low900rr
Will a tilt column from a late 80's camaro work??? Im gonna use a lokar shifter mounted to the trans so I wont be using any linkages or cables. thanks
Old 08-03-2008, 12:00 PM   #8
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Any GM column will work, but a 70-80 van will look better and fit better. All GM columns from 73-95ish are all the same, just differant lengths, which can be changed very easy.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 08-05-2008, 09:37 PM   #9
low900rr
how about a column from a 1972 blazer??? is this is good swap?? thanks for the help
