08-04-2008, 08:56 PM | #1 |
3.08 vs. 3.73
I have an NV3500 with a .73 5th gear. I have 3.73 gears now. First gear is so low geared I hardly use it other than starting on hills. I have 27" tires. I want to put 3.08 gears in it. Does anyone have this combo? I have a 355 with about 300hp so I think the low rpm at highway speed won't be hard to maintain.
08-04-2008, 09:46 PM | #2 |
Re: 3.08 vs. 3.73
My calculator says you will go from 60 mph at 2000 rpm to 72 mph. SHould work ok. You will have to change the carrier to a series 3, more $$$ than just a ring and pinion.
Mine is chopped, has a clutch, and a big block. |
08-04-2008, 10:01 PM | #3 |
Re: 3.08 vs. 3.73
1st is an underdrive.Figure on 2nd gear starts under normal driving.
08-04-2008, 10:07 PM | #4 |
its all about the +6 inches
Re: 3.08 vs. 3.73
1, 2 and 3 are all underdrives.
If you drive at 70 MPH, then it may work out OK. If you drive at 60, your MPG will probably get worse, not better. |
08-04-2008, 10:58 PM | #5 |
Re: 3.08 vs. 3.73
I'd stick with the 3.73s, I don't think you'd get much use out of a 3.08 with a .73 overdrive. I've got a couple of 3.08s and they're marginal with a 1:1 final gear, pretty much worthless for towing anything but a light trailer. 3.08 x .73 = 2.25, that's a pretty high gear.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
08-04-2008, 10:56 PM | #6 |
Re: 3.08 vs. 3.73
What I meant was 1st is a creeper gear.
08-04-2008, 11:06 PM | #7 |
Re: 3.08 vs. 3.73
I agree with Bob.I think of a truck with 3.08s as overdrive.You need bottom torque to get them rolling.I wasn`t thinking about the rear,but the transmission in my last answer.When I saw the title my first thought was,"What about 3.42s?"I consider that my threshold for o/d.It`s not bad w/o and can still pull with o/d as long as you have low-end torque.That`s how most Tahoes come ,as far as what I`ve seen.That should give you some idea of where they lie.It`s not a heavy hauling set-up,but can tow.
I run 4.10 & o/d in my one ton and love it.Hauls loads ans hauls azz.Can`t beat that!
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-05-2008 at 06:57 AM. |
08-04-2008, 11:25 PM | #8 |
Re: 3.08 vs. 3.73
3.73 gears times .73 equals a final drive of 2.72. The 3.08 times the overdrive comes out to 2.15. I'd keep the 3.73s
