Anyone have any pics of a factory 67 to 72 1 ton 4x4. Was there even one made? Just curious.
Hillbilly Hotrod
The 1 ton 4x4 made its debute in 1978. 14 bolt FF and a D60 front.
The 8 lug rigs of the 67-72 era are rated at 3/4 ton and quite a few will have an Eaton rear axle, and some have a Factory Detroit in them as well. D44 fronts with the closed knuckle till 71 I believe. External hubs, big suckers too. external hubs went till 76 then the internal ones. for 3/4 ton rigs. In 78 The general decided to install a D60 front axle and call it a K30. Either in a dually or a SRW rig, regular cab or a 4 door(3+3)
69 K5, .060 over 350/465/205. |
Actually, '77 was the first year for the K30. Definitely no such thing in '67 - '72 though.
Tim |
I was going to say they had them in 77 because a friend bought his 1 ton 4x4 new in77. Ihave a 77 4 door single wheel 1 ton 4x4. Interesting both trucks use blocks under the springs and 2wd spring hangers in the rear. I have a 79 1 ton 4x4 that has the longer spring hangers to increase the ride hieght. I guess in 77 gm hadn't came up with the longer spring hanger for the 1 ton 4x4 yet. Oh the reason I asked if there were factory 72 1 ton 4x4 is there is a guy running around in one and claims it was a fctory 4x4. I guess I could of been a 1 ton 4x4 since new but I would probaly guess it was converted when brand new by a conversion co.
If it's a 67-72 1-ton 4 wheel drive, it's a conversion. Anyone that tells you different is either mislead or lying.
I'm pretty sure that the Dana44 went open knuckle in '70 (at least in Chevy). Not 100%, but I'd bet a Lincoln on it if I had to. I thought I noticed that in a service manual. I'll have to check.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Just for the record. I had a late '69 with an open knuckle front end. I think '69 must have been a transition year. Gee, I could use a Lincoln.....
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
![]() Join Date: Feb 2000
My 69 is a closed knuckle and I think your right that it was a transition year. Mine has the Rockwell T-221 transfer case.
What does yours have? Seems like most of the 69 trucks had the Rockwell, but not the Blazers. Looks like were all in agreement that no 67-72 factory 1 ton 4x4's. Here is a pic of my good friend's 70 1 ton that he converted to 4x4. He did a great job. ![]() More of it can be seen at http://www.j0ker.org/~yukon/tonys70.html
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I thought '70 was the transition year.
My '69 has closed knuckle with a rockwell. The service manual shows the '69 with a closed knuckle and the '70 with an open.
i thought in '69 the trucks had the closed knuckle but,the blazer came with the open knucle.
my blazer (a '69) has open knuckle/drum brakes/dana 20 transfer case. ckhd,i've been meaning to ask you:what ever happend to the game & fish blazer that was auctioned off near you?did you break down and buy it? buckshot Last edited by buckshot; 11-16-2002 at 09:41 PM. |
The '69 I was talking about was a 3/4 ton and it also had the NP205 transfer case with 4 speed. It was a loaded truck with AC and a NoSpin rear.
![]() Join Date: Dec 2000
I had a '69 blazer as well with open knuckle front and 350/205 tranny/transfer combo. Bought from original owner who said the only thing changed was the weak 6cyl. for a 327.
Matthew
GOD is good...All the time! '71 swb custom10 barn find-68K original miles 72 K5 CST rust bucket, but runs and drives 84K miles |
Buckshot,
I wish I had bought it. It went to someone local for $1600.
Got Big Block?
i'ts 3AM where I in Texas. I had to take a leak so I thought I'd take a look and saw this thread. I'm half asleep, but thought ya'll might like this pic. You've probabley already seen it.
"Experience is what you get when you didn't get what you wanted." |
That would be nice wouldn't Purs. I bet those tires cost a good penny. I have a old duece and a half that looks to have the same front axle.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
#15 |
Actually you can get the exact cut tires from usa6x6.com fairly cheap.That is a cool looking ride.Wish I had 2.5 ton axles under my rig.
72' Camper Special,454,th350,np205,4.56 locker,dana44 with spool,13" of lift and 44" boggers.soon to be 23" with rear disc brakes |
#16 |
Best story I've seen on 1 ton conversion. Lots of pics too.
http://www.ccountry.net/~tmobrien/trucks/napco/71napco/
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#17 |
Thats a nice 1 ton con. Rod. Can anyone tell me what kind of front axle that one is? Check out the steering linkage on that truck also.
#18 |
Drivetrain: 1-ton "NAPCO" 4-Wheel Drive Front Axle, Rzeppa Closed Knuckle CV Joints/Steering Knuckles, Warn Model M-23 Locking Hubs, NP-205 Transfer Case, Heavy Duty (11,000 lb) Chevrolet Rear Axle, Dual Rear Wheels, Drum Brakes all around, 3.73 Ring and Pinion Gears.
#19 |
R U sure?
Greetings....
I'm here as I'm trying to get more info on a truck I'm going to look at-it's listed in the local want ads as a '69 1 ton, dually (with flatbed dump) 4x4.... So might this NOT be a factory set up? Any info, thoughts would be appreciated... Couchsachraga |
#20 |
I think they would have to been done aftermarket. . . .
#21 |
Greetings...
Just spoke to the fellow-'69 flatbed dump, dually, 4wd, he assumes it's a one ton because of all the springs and does not know of a designation on it (e.g. c20, c30, etc...). He bought it from someone using it to haul wood and has used it to haul construction debris to the dump. It's got a newer 350 in it mated to a 4 speed. Cab corners are rusty (he filled them with expanding foam). Needs new lockout hubs (he says they dont' lock anymore). Any thoughts as to its value (northeast US)? Time to price hubs.... Thanks, Couchsachraga |
