dash pad
has anyone covered a dash pad in tweed fabric ? does the pad itself have to be perfect or can i fill the cracks with flexable filler ? or maybe use a form fit cover on it then use the fabric? also the door panels, do they need to be perfect ? any help will be appreciated.......art
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: dash pad
if youre using fabric you would have to make the dash pad smooth or you will see the crack... id prolly cut the edges of the crack with a straight edge blade then use fiberglass to fill in the crack so its good and smooth... any thing else would prolly not stay as well you could also put a little foam insulation on the dash before you put on the material the kind like they use under laminate floors or for packaging things
the door panels are plastic those as long as no pieces are missing around the edges, bondo will work ok to patch cracks or even holes that arent too big fiberglass for stuff bigger good luck
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 08-10-2008 at 09:50 AM. |
