Old 11-14-2002, 11:18 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Does This Sound OK or no...
Saw this on EBAY...http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872360251
Is this what I need to Put 3.54's in and What would i do for axles, will my 12 bolt axles work???
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 11-14-2002, 11:35 PM   #2
mikep
Used to have a truck
mikep's Avatar
I'm assuming that you have 12 bolt chevrolet rear end in that half ton truck of yours. In which case you would have a really difficult time putting that Dana 60 carrier in it. Dana 60 and 10 or 12 bolts are completely different objects and no parts interchange between them. It wont fit.
Either way even if you had a Dana 60, which you do not, that carrier wouldnt do you any good. Its a plain old open differential and is neither a Posi Nor is it a locker. I'd suggest you ask pertinent questions like... what is a posi, what is a detroit locker, what kind of rear end do I have , what do I need to have. etc.
By the way ... I have a 3.54 geared detroit locker Dana 60 with coil springs...And its mine all mine muhaha
No truck :-(
mikep is offline   Reply With Quote
